Lenovo ThinkVision T22v-10 LED monitor 21.5" 1920 x 1080
Quicklinx: F4Y3WS00 Mfr#: 61BBMAT6UK
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
29 in stock
£158.36 ex VAT
£190.03 inc VAT
Standard delivery Delivered within 3-5 working days
This outstanding 21.5" professional monitor is built for collaboration and conferencing with an integrated webcam, microphone and speakers. But there's no sacrificing display performance with bright, rich color and near-edgeless In-Plane Switching panel to ensure optimized visual experience. This excellent VoIP solution features a full range of connectivity options and full-function stand to suit any environment.
  • Easy conferencing
    Conference calls are a breeze with integrated webcam with privacy lock, speakers and microphone.
  • Easy sign-in
    With Windows Hello supported devices such as smartwatches, smart bracelets or smartphones, you'll get enhanced security without having to type in a password.
  • Easy on the eyes
    The near-edgeless 21.5" In-Plane Switching screen provides exceptional visuals across wide-viewing angles.
Lenovo ThinkVision T22v-10 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Microphone, USB 3.0 hub, FHD IR camera
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms (typical); 4 ms (extreme)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
48.97 cm x 25.19 cm x 48.58 cm
4.61 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
FCC Class B certified, RoHS, ISO 9241-307, WEEE, DDC-2B/CI
3-year warranty
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
WLED
72% colour gamut
4.61 kg
Audio
Speakers - stereo
Input
Microphone
DisplayPort (HDCP) , HDMI (HD-15) , VGA , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream , Audio line-in , Audio line-out
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, detachable stand
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m , 1 x HDMI cable - 1.8 m
Mounting Kit
Optional
Security Slot Type
Kensington security slot
18 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Microsoft Windows 7 / 10
ENERGY STAR Certified
TCO Certified
Limited warranty - 3 years , - backlight - 3 years
Lenovo ThinkVision T22v-10 LED monitor 21.5 Bundle deal on Lenovo ThinkVision T22v-10 LED monitor 21.5" 1920 x 1080
£257.53
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: F4Y3 042108
Condition: Customer return - item has been repaired under warranty by the manufacturer. Please Note: This item does not come in its original packaging.
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not present or functional  £121.17
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Lenovo
Stock Status: Used Stock
Price Range Ex VAT: 150 - 300
