Lenovo ThinkVision T2254p 22" 1680x1050 5ms VGA HDMI DisplayPort LED Monitor
Quicklinx: BL67WS00 Mfr#: 60CCMAT2UK
Designed for businesses, T2254p offers high-quality performance, a comfortable viewing experience and green credentials. With its 22" widescreen in 16:10 aspect ratio and 1680 x 1050 resolution, T2254p offers more than enough desk space needed to boost productivity. It has multiple connectivity options – VGA, HDMI 1.4, DP 1.2 – making it a suitable choice for professional notebook and desktop PC users seeking a multi-monitor setting. With a lightning-fast speed of 5 milliseconds, 250 nits brightness, 72% colour gamut and 1000:1 contrast ratio, this product offers more than enough visual clarity for comfortable viewing. Plus, the full-function, ergonomic stand with tilt, lift, pivot and swivel features makes collaboration more effective. And with no compromise on performance, the T2254p meets the most stringent environmental and ergonomic certifications including Energy Star 6.0, TCO 6.0, TCO Edge 2.0, EPEAT Gold, ULE Gold, TUV Green Mark, CEL Tier 1 and more.
Lenovo ThinkVision T2254p - LED monitor - 22"
LED-backlit LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100/240 V / DC 12 V (50/60 Hz)
Raven black
50.93 cm x 24.26 cm x 48.17 cm
5.6 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, VCCI, C-Tick, BSMI, IEC950, NEMKO, NOM, SABS, SASO, TUV S, CCC, IC, PSB, Lead-Free, ISO 9241-307, WEEE, PSE Mark, JEITA, cTUVus, MEPS, E-Standby, TUV GM, KC, Kvalitet, KUCAS, SONCAP, KEBS, CECP, UL Environmental SPC Gold, INSM, EAC, China RoHS, ISC, Energy-Related Products (ErP) Lot 5
3-year warranty
Display Type
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72%
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 81 kHz
Video Bandwidth
205 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, input select
Raven black
50.93 cm x 24.26 cm x 48.17 cm - with stand
5.6 kg
VGA , DisplayPort , HDMI , Audio line-out
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Microsoft Windows 7, Windows 8, Windows 8.1
Dimensions & Weight Details
Without stand - width: 50.93 cm - depth: 4.4 cm - height: 37.17 cm - weight: 2.85 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - replacement - 3 years - carry-in
45 °C
10 - 80%
BL67 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
