Designed for businesses, T2254p offers high-quality performance, a comfortable viewing experience and green credentials. With its 22" widescreen in 16:10 aspect ratio and 1680 x 1050 resolution, T2254p offers more than enough desk space needed to boost productivity. It has multiple connectivity options – VGA, HDMI 1.4, DP 1.2 – making it a suitable choice for professional notebook and desktop PC users seeking a multi-monitor setting. With a lightning-fast speed of 5 milliseconds, 250 nits brightness, 72% colour gamut and 1000:1 contrast ratio, this product offers more than enough visual clarity for comfortable viewing. Plus, the full-function, ergonomic stand with tilt, lift, pivot and swivel features makes collaboration more effective. And with no compromise on performance, the T2254p meets the most stringent environmental and ergonomic certifications including Energy Star 6.0, TCO 6.0, TCO Edge 2.0, EPEAT Gold, ULE Gold, TUV Green Mark, CEL Tier 1 and more.
- Lenovo ThinkVision T2254p - LED monitor - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050 at 60 Hz
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100/240 V / DC 12 V (50/60 Hz)
- Raven black
- 50.93 cm x 24.26 cm x 48.17 cm
- 5.6 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, TUV GS, VCCI, C-Tick, BSMI, IEC950, NEMKO, NOM, SABS, SASO, TUV S, CCC, IC, PSB, Lead-Free, ISO 9241-307, WEEE, PSE Mark, JEITA, cTUVus, MEPS, E-Standby, TUV GM, KC, Kvalitet, KUCAS, SONCAP, KEBS, CECP, UL Environmental SPC Gold, INSM, EAC, China RoHS, ISC, Energy-Related Products (ErP) Lot 5
- 3-year warranty
- Display Type
- Diagonal Size
- 22"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 81 kHz
- Video Bandwidth
- 205 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, input select
- Raven black
- 50.93 cm x 24.26 cm x 48.17 cm - with stand
- 5.6 kg
- VGA , DisplayPort , HDMI , Audio line-out
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- Localisation
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- OS Required
- Microsoft Windows 7, Windows 8, Windows 8.1
- Dimensions & Weight Details
- Without stand - width: 50.93 cm - depth: 4.4 cm - height: 37.17 cm - weight: 2.85 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - replacement - 3 years - carry-in
- 0 °C
- 45 °C
- 10 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black | In Stock | £14.57 |
