Lenovo ThinkVision T2220 21.5" 1920x1080 5ms VGA DVI LED Monitor
Quicklinx: 9LX5WS00 Mfr#: 60B7HAT1UK
The ThinkVision T2220 21.5-inch WLED Backlit LCD Monitor meets all users' functional needs in both work and home environments. The WLED backlit panel with wide screen 1920 x 1080 resolution provides full-HD quality to customers. Its popular 16:9 aspect is increasingly becoming standard in the market. With built-in VGA + DVI interfaces and tiltable stand, it offers a comfortable usage experience. Compatible with Windows 7, Windows 8 and Windows 8.1, allowing more flexible usage. In addition, it is environmentally conscious, meeting the latest green standards including US Energy Star 6.0 Certified, TCO 6.0, China Energy Standard Tier1, EPEAT Gold Certification and VOC test.
Lenovo ThinkVision T2220 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
DVI, VGA
Display Position Adjustments
Height, tilt
Voltage
Raven black
51.26 cm x 17.72 cm x 35.63 cm
6.11 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, CSA, TUV GS, VCCI, C-Tick, BSMI, IEC950, NEMKO, NOM, SABS, SASO, CCC, IC, PSB, IRAM, RoHS, ISO 9241-307, KCC, WEEE, Green Mark, JEITA, cTUVus, MEPS, E-Standby, KC, Kvalitet, KUCAS, SONCAP, KEBS, CECP, UL Environmental SPC Gold, BELLIS, KONCAR, INSM, EPA 6.0, CEL Grade 1, ISC
3-year warranty
Display Type
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
307
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72%
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Video Bandwidth
205 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, H/V position, input select, colour temperature
OSD Languages
Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
Raven black
51.26 cm x 17.72 cm x 35.63 cm - with stand
6.11 kg
DVI , VGA (DB-15)
Mechanical
Height, tilt
1 x VGA cable - 1.8 m
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
27 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Microsoft Windows 7 / Windows 8, Windows 8.1
Dimensions & Weight Details
With stand - width: 51.26 cm - depth: 17.72 cm - height: 35.63 cm - weight: 6.11 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - replacement - 3 years - carry-in
45 °C
10 - 80%
9LX5 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
