The ThinkVision T2014 features a 19.5" display with built-in power for ease of use. It has 5ms response time, 250 nits brightness and 1000:1 native contrast ratio. With a clean appearance, T2014 has tilt stand, VGA and DVI interface. It's all for your flexible use. Following a tradition of ThinkVision products, ThinkVision T2014 is also respectful to the environment with numerous certifications including Energy Star 6.0, TCO certification, EPEAT Gold and many others.
- Lenovo ThinkVision T2014 - LED monitor - 19.5"
- LED-backlit LCD monitor - 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900 at 75 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- 47.3 cm x 18.98 cm x 35.21 cm
- 2.53 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, CSA, TUV GS, VCCI, C-Tick, BSMI, IEC950, NEMKO, NOM, SABS, SASO, CCC, IC, TUV Ergo, PSB, RoHS, ISO 9241-307, KCC, WEEE, JEITA, cTUVus, MEPS, E-Standby, TUV GM, KC, Kvalitet, KUCAS, SONCAP, KEBS, CECP, EMI, DDC-2B/CI, UL Environmental SPC Gold, BELLIS, KONCAR, INSM, EPA 6.0, CEL Grade 1, China RoHS, CSM, ISC
- 3-year warranty
- Display Type
- Diagonal Size
- 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Video Bandwidth
- 205 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, H/V position, colour balance, input select
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
- HDCP
- Raven black
- 47.3 cm x 18.98 cm x 35.21 cm - with stand
- 2.53 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m
- Localisation
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
- Microsoft Windows 7 / 8 / 8.1
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - replacement - 3 years - carry-in
