Brand
Lenovo ThinkVision S28u-10 28" 3840x2160 HDMI DisplayPort IPS LED Monitor
Quicklinx: FPV7WS00 Mfr#: 61E6GAT2UK
Diagonal Size: 28in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: None
Interfaces: DisplayPort, HDMI
36 in stock
£272.44 ex VAT
£326.92 inc VAT
The Lenovo ThinkVision S28u-10, sporting a 28-inch In-Plane Switching panel, offers professional monitor features while remaining a smart and intelligent business investment. The 4K UHD resolution screen has a 99% accurate sRGB color gamut and 90% accurate DCI-P3 color gamut, delivering pixel-perfect clarity that's ideal for multitasking, analytics, and graphic designing tasks. The NearEdgeless screen with wide viewing angles is aesthetic and effective in equal measure, enhancing collaboration capabilities. Equipped with both an HDMI 2.0 port and DisplayPort 1.2, the ThinkVision S28u-10 delivers flexible connectivity. For maximum user comfort, the natural low blue light emission minimizes eyestrain and enables an enjoyable viewing experience.
  • Eye-catching display
    Experience superior visual output on the ThinkVision S28u-10 that has a 7.5% larger display area than 27-inch monitors of the same resolution. Crystal-clear visuals on the 4K UHD In-Plane Switching panel means no detail is too small.
  • Comfortable user experience
    Eyestrain is minimized thanks to the natural low blue light solution that reduces blue light emission without compromising color accuracy, brightness, or power efficiency.
  • Enhanced connectivity
    The monitor has HDMI 2.0 and a DisplayPort 1.2 that provide improved connectivity required for modern businesses.
Lenovo ThinkVision S28u-10 - LED monitor - 4K - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class F
Power Consumption (On mode)
26.4 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1617 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
6 ms (typical); 4 ms (extreme)
Colour Support
1.07 billion colours
Colour Gamut
99% sRGB, 90% DCI-P3
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
Raven black
63.694 cm x 22.999 cm x 45.082 cm
5.24 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
CCC, RoHS, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
28"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1617 mm
Pixel Per Inch
157.35
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
NearEdgeless, 99% sRGB colour gamut
Raven black
5.24 kg
HDMI , DisplayPort , Audio line-out (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
26.4 W
26.4 kWh/1000h
Power Consumption (Typical)
28 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Microsoft Windows 7, Windows 10
Dimensions & Weight Details
With stand - width: 63.694 cm - depth: 22.999 cm - height: 45.082 cm - weight: 5.24 kg , Without stand - width: 63.694 cm - depth: 4.92 cm - height: 37.368 cm - weight: 4.58 kg
Shipping Width
45.2 cm
Shipping Depth
12.7 cm
Shipping Height
72.3 cm
Shipping Weight
7 kg
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
Diagonal Size: 28in
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Brand: Lenovo
Stock Status: In stock
