Lenovo ThinkVision S24q-10 23.8" 2560x1440 4ms VGA HDMI IPS LED Monitor
Quicklinx: FPV0WS00 Mfr#: 61E7GAT1UK
Diagonal Size: 23.8in
Max Resolution: 2560 x 1440
Interfaces: HDMI, DisplayPort
£175.53 ex VAT
£210.63 inc VAT
Uncompromised clarity and an amazing visual experience make the ThinkVision S24q a perfect monitor. This is best suited for small businesses looking for high-quality visuals, excellent performance, and user convenience. Its 23.8-inch In-Plane Switching (IPS), QHD display has wide viewing angles, making it ideal for business executives, graphic artists, and freelancers. The monitor is Low Blue Light certified, ensuring longer hours of productivity.
Lenovo ThinkVision S24q-10 - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class F
Power Consumption (On mode)
19.7 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 75 Hz
Pixel Pitch
0.2058 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
14 ms (typical); 6 ms; 4 ms (extreme)
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
Raven black
53.98 cm x 20 cm x 40.27 cm
3.5 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
CCC, RoHS, DisplayPort 1.2, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
23.8"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2058 mm
Pixel Per Inch
123
Brightness
300 cd/m²
Contrast Ratio
Response Time
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 114 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
99% sRGB colour gamut, NearEdgeless
Raven black
53.98 cm x 20 cm x 40.27 cm - with stand
3.5 kg
DisplayPort 1.2 , HDMI , Audio line-out (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
19.7 W
19.7 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 53.98 cm - depth: 20 cm - height: 40.27 cm - weight: 3.5 kg , Without stand - width: 53.98 cm - depth: 4.2 cm - height: 32.57 cm
Shipping Width
63.9 cm
Shipping Depth
12.2 cm
Shipping Height
40.5 cm
Shipping Weight
5.1 kg
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
10 - 80% (non-condensing)
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Lenovo
Stock Status: In stock
