The 21.5" S22e-19 ThinkVision monitor with 178° wide viewing angle displays clearer images across the screen, and the flicker-free display reduces motion blur on fast-moving videos. Ideal for any kind of office environment, this monitor boosts productivity with versatile connectivity options, TÜV Low Blue Light certification, and a quick-release tilt stand for comfortable working modes.
Wide viewing angles
With horizontal and vertical viewing angles of 178 degrees, the Lenovo ThinkVision S22e-19 offers a consistent and vibrant display from all perspectives, ensuring a high-quality viewing experience for multiple users or when viewing from different positions. -
Optimized connectivity
Featuring HDMI and VGA interfaces, this monitor provides versatile connectivity options, allowing for easy setup and integration with a wide range of devices. -
Energy efficient
Certified by ENERGY STAR, the Lenovo ThinkVision S22e-19 is designed to reduce energy consumption without compromising on performance, making it an eco-friendly choice for your computing needs. -
Enhanced visual clarity
The monitor boasts a dynamic contrast ratio of 3000000:1, Full HD resolution, and WLED backlight technology, delivering sharp, vivid images with deep blacks and bright whites. -
Comfortable viewing experience
Tilt adjustments ranging from -5 to +22 degrees, combined with TUV Rheinland Low Blue Light Certification, ensure a comfortable viewing experience, reducing eye strain during long usage periods.
- Lenovo ThinkVision S22e-19 - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/373102
- Energy Class
- Class D
- Power Consumption (On mode)
- 11.5 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms (extreme), 6 ms (typical)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- 48.93 cm x 20 cm x 37.38 cm
- 2.75 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- CCC, EMC, FCC, DDC/CI, RoHS, WEEE, TUV Rheinland Low Blue Light Certification, China Energy standard Tier 2, VESA TMDS
- 3-year warranty
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 21.5"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Pixel Per Inch
- 102
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Vertical Refresh Rate
- 49 - 76 Hz
- Horizontal Refresh Rate
- 54 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Anti-glare
- Raven black
- 48.93 cm x 20 cm x 37.38 cm - with stand
- 2.75 kg
- HDMI , VGA (HD-15) , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management
- Cables Included
- 1 x HDMI cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 11.5 W
- Power Consumption SDR (On mode)
- 11.5 kWh/1000h
- Power Consumption (Typical)
- 18 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- OS Required
- Microsoft Windows 7 / 10
- Dimensions & Weight Details
- With stand - width: 48.93 cm - depth: 20 cm - height: 37.83 cm - weight: 2.75 kg , Without stand - width: 48.93 cm - depth: 4.15 cm - height: 29.68 cm - weight: 2.46 kg
- Shipping Width
- 58.2 cm
- Shipping Depth
- 12 cm
- Shipping Height
- 35 cm
- Shipping Weight
- 4.07 kg
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
