Your basket is empty
Lenovo ThinkVision Pro2820 28" 1920x1080 6.5ms VGA HDMI DisplayPort LED Monitor
Quicklinx: B06DWS00 Mfr#: 60B5RAT6UK
The ThinkVision Pro2820 features a FHD display with WVA technology. With true 8 bit color, 6.5ms response time, 300 nits brightness, 3000:1 native contrast ratio, the latest premium ThinkVision monitor is designed to offer an uncompromised display experience. A wide viewing angle MVA panel with a three million to one dynamic contrast ratio offers vibrant and vivid image from any angle. A full function stand allows tilt, swivel and rotate and includes VGA, DisplayPort, HDMI/MHL and multiple USB 3.0 ports. It's all for your flexible and easy use. Following a tradition of ThinkVision products, ThinkVision Pro2820 is also respectful to the environment.
Lenovo ThinkVision Pro2820 - LED monitor - Full HD (1080p) - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class A
Energy Consumption per Year
40.7 kWh
Power Consumption (On mode)
27.9 W
USB 3.0 hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
20 ms (On/Off); 6.5 ms (typical)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, MHL, DisplayPort
Display Position Adjustments
66.59 cm x 28.89 cm
8.11 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, VESA EDID, RoHS, ISO 9241-307, TUV GM, DDC-2B/CI, TCO Displays, TCO Displays 6.0, UL Environmental SPC Gold, TCO Certified Edge 1.2, China RoHS
3 years warranty
Display Type
Energy Class
Class A
40.7 kWh
27.9 W
Diagonal Size
28"
Viewable Size
28"
Built-in Devices
USB 3.0 hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
HDCP, anti-glare, 72% colour gamut
66.59 cm x 28.89 cm - with stand
8.11 kg
MHL / HDMI (HDCP) , DisplayPort (HDCP) , VGA (HD-15) , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Power Supply
Internal
Power Consumption Sleep
1.2 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 66.59 cm - depth: 28.89 cm - weight: 8.11 kg , Without stand - width: 66.59 cm - depth: 5.82 cm
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
8 - 90%
B06D C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
B06D C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
B06D C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
B06D C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
B06D C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
B06D C2G Pro HDMI to VGA Converter In Stock £46.35
