Product
Brand
Lenovo ThinkVision Pro 2840m 28" 3840x2160 7ms HDMI DisplayPort LED Monitor
Quicklinx: 9LX6WS00 Mfr#: 60B4RAT6UK
The ThinkVision Pro2840m features a 4K display. With a3840x2160 panel, 10-bit colour, 270-nit brightness and 5-millisecond response time, the latest premium ThinkVision monitor is designed to offer an uncompromised display experience. With 157 pixels per inch and a three million to one dynamic contrast ratio, the stunning image is vibrant, sharp and detailed. The infinity glass design features touch-sensitive buttons and dual speakers. A full-function stand allows tilt, swivel and rotate, and includes DisplayPort, HDMI and multiple USB ports.ThinkVision Pro2840m is also respectful to the environment with numerous certifications including Energy Star 6.0, TCO certification, EPEAT Gold and many others.
Lenovo ThinkVision Pro2840m - LED monitor - 4K - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class C
Energy Consumption per Year
68.8 kWh
Power Consumption (On mode)
47.1 W
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
5 ms
Input Connectors
HDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
66.59 cm x 28.93 cm x 44.325 cm
10.19 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, CSA, TUV, VCCI, C-Tick, BSMI, GOST, DDC-2B, IEC950, NEMKO, NOM, SABS, SASO, TUV S, VESA EDID, CB, CCC, IC, DDC/CI, RoHS, ISO 9241-307, KCC, WEEE, Green Mark, JEITA, cTUVus, MEPS, E-Standby, KC, Kvalitet, KUCAS, SONCAP, KEBS, CECP, DDC-2B/CI, UL Environmental SPC Gold, BELLIS, KONCAR, INSM, TCO Certified Edge 1.2, CEL Grade 1, CSM
3 years warranty
Display Type
Energy Class
Class C
68.8 kWh
47.1 W
Diagonal Size
28"
Viewable Size
28"
Built-in Devices
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
5 ms
Vertical Refresh Rate
25 - 70 Hz
Video Bandwidth
594 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP
66.59 cm x 28.93 cm x 44.325 cm - with stand
10.19 kg
Audio
Speakers
HDMI , DisplayPort , Mini DisplayPort , USB 2.0 upstream , USB 2.0 downstream
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
1 x HDMI cable - 1.8 m , 2 x USB cable - 1.8 m
Power Supply
Internal
On / Off Switch
Microsoft Windows 7 / Windows 8, Windows 8.1
Dimensions & Weight Details
With stand - width: 66.59 cm - depth: 28.93 cm - height: 44.325 cm - weight: 10.19 kg
ENERGY STAR Certified
Limited warranty - replacement - 3 years - carry-in
8 - 80%
9LX6 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
9LX6 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.07
9LX6 C2G 5m Select High Speed HDMI with Ethernet In Stock £16.55
9LX6 C2G 10m Select High Speed HDMI with Ethernet In Stock £32.58
9LX6 C2G 15m Select High Speed HDMI with Ethernet In Stock £43.66
9LX6 C2G Pro HDMI to VGA Converter In Stock £49.54
