Lenovo ThinkVision P44w-10 43.4" 3840x1200 HDMI DisplayPort USB-C LED Monitor
Quicklinx: FGN7WS00 Mfr#: 61D9RAT1UK
Diagonal Size: 43.4in
Max Resolution: 3840 x 1200
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, USB-C
Hurry, only 1 left in stock!
£999.44 ex VAT
£1,199.32 inc VAT
Offering a stunning visual experience, the ThinkVision P44w-10 allows you to be more productive every day. The 43.4-inch large screen real estate and the wide viewing angle make content creation and consumption exceptional. The versatile connectivity ports expand your device capabilities by enabling easy connection to other peripherals. Packed with advanced features, this monitor is your perfect canvas to amplify productivity.
  • One is better than two
    The ThinkVision P44w-10 offers a curved display, designed in a way that allows you to enjoy the screen space of approximately two 24-inch 16:10 monitors on a single 43.4-inch 32:10 monitor. The picture-by-picture (PBP) and picture-in-picture (PIP) functionality with KVM switch helps you manage up to two video inputs for seamless multitasking and viewing content from up to two devices at ease. Moreover, the lift, tilt, and swivel functionality allows you to position the monitor in a way that suits your working style.
  • Experience superior connectivity
    With two innovative USB 3.1 Type-C ports, you can connect up to two devices, transfer data, video/audio, and manage up to 90W power for devices such as smartphones, laptops, workstations, tablets, or desktops simultaneously. The one-push port-hub houses two USB 3.1 ports and an audio jack to enable easy plug and play connectivity needs for home, office and entertainment alike. With the Smart Power function that intelligently detects power consumption and efficiently manages power supply, users can charge two compatible devices simultaneously. Advanced ports such as DisplayPort 1.4 and HDMI 2.0 offer more connectivity options.
  • Display with a perspective
    This anti-glare curved monitor with TÜV Eye Comfort certification reduces eye-strain and makes it easy for you to power through extended working hours. Moreover, the 3840 x 1200 pixels resolution combined with VESA Certified Display HDR 400 picture clarity offers crisp visuals. The 144Hz refresh rate enables you to enjoy content consumption without any lags . With the multiple color spaces, pre-calibrated color accuracy, and the ThinkColor software, content creation tasks are a breeze. The optional Harman Kardon certified speaker along with the immersive display offers an integrated audiovisual experience.
Lenovo ThinkVision P44w-10 - LED monitor - curved - 43.4" - HDR
LED-backlit LCD monitor - 43.4"
Energy Class
Class G
Power Consumption (On mode)
49 W
Curved Screen
USB 3.1 hub
Panel Type
VA
Aspect Ratio
32:10
Native Resolution
3840 x 1200 at 144 Hz
Pixel Pitch
0.274 mm
Brightness
450 cd/m²
Contrast Ratio
3000:1 / 3000000:1 (dynamic)
HDR Capable
DisplayHDR 400
Response Time
6 ms (typical); 4 ms (extreme)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort, 2xUSB-C
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
Voltage
Raven black
1.0583 m x 26.98 cm x 46.11 cm
13.45 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
CCC, RoHS, DisplayPort 1.2, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification, DisplayPort 1.4, ULE Gold
3-year warranty
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
Diagonal Size
43.4"
Viewable Size
43.4"
Curved Screen
Yes (1800R)
Built-in Devices
USB 3.1 hub
Panel Type
VA
Aspect Ratio
32:10
Native Resolution
Pixel Pitch
0.274 mm
Pixel Per Inch
93
Brightness
450 cd/m²
Contrast Ratio
HDR Certification
DisplayHDR 400
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
PIP 2.0, PBP, 90% DCI-P3, 99.5% sRGB colour gamut, 178° viewing angle, 99.5% BT.709 colour gamut, NearEdgeless
Raven black
1.0583 m x 26.98 cm x 46.11 cm - with stand
13.45 kg
Audio
Speakers - stereo
Output Power / Channel
4 Watt
DisplayPort , 2 x HDMI , 4 x USB 3.1 Gen 1 downstream , USB-C 3.1 Gen 1 upstream/DisplayPort , USB-C 3.1 Gen 2 upstream/DisplayPort , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+22
Swivel Angle
60
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB 3.1 Gen 2 cable - 1.5 m
Security Slot Type
Kensington security slot
Input Voltage
49 W
49 kWh/1000h
Power Consumption HDR (On mode)
80 kWh/1000h
Power Consumption (Typical)
70 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Included Software
ThinkColor
Microsoft Windows 7 / 10
Dimensions & Weight Details
With stand - width: 1.0583 m - depth: 26.98 cm - height: 46.11 cm - weight: 13.45 kg , Without stand - width: 1.0583 m - depth: 13.72 cm - height: 36.61 cm - weight: 9.35 kg
Shipping Width
1.219 m
Shipping Depth
37.6 cm
Shipping Height
50 cm
Shipping Weight
18.59 kg
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.1
Limited warranty - 3 years
45 °C
Response Time: 4ms
Interfaces: HDMI
Interfaces: USB-C
Brand: Lenovo
Price Range Ex VAT: £750 - £1000
Stock Status: In stock
