The Lenovo ThinkVision P32u-10 display makes your creative ideas come to life. It delivers lightning-fast, one-cable connection for power, data, video and audio. At the same time, you can truly boost productivity and enjoy a stunning visual experience by connecting dual monitors via Thunderbolt 3 out.
- Lenovo ThinkVision P32u-10 - LED monitor - 4K - 32"
- LED-backlit LCD monitor - 32"
- USB 3.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.1845 mm
- Input Connectors
- 2xHDMI, DisplayPort, Thunderbolt 3
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- 72.67 cm x 35 cm x 49.78 cm
- 10 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- DDC/CI, VESA TMDS
- Display Type
- Diagonal Size
- 32"
- Built-in Devices
- USB 3.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1845 mm
- Vertical Refresh Rate
- 23 - 80 Hz
- Horizontal Refresh Rate
- 30 - 160 kHz
- Backlight Technology
- LED backlight
- Raven black
- 72.67 cm x 35 cm x 49.78 cm - with stand
- 10 kg
- 2 x HDMI , Thunderbolt 3 , DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out (mini-jack)
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- DDC/CI, VESA TMDS
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 57 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- OS Required
- Microsoft Windows 7 / 10 (32/64 bits)
- Dimensions & Weight Details
- Without stand - width: 72.67 cm - depth: 6.33 cm - height: 43.15 cm - weight: 6.9 kg , With stand - width: 72.67 cm - depth: 35 cm - height: 49.78 cm - weight: 10 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
