Brand
Lenovo ThinkVision P27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor
Quicklinx: FPV4WS00 Mfr#: 61EAGAT6UK
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Interfaces: HDMI, Mini DisplayPort, DisplayPort
More than 50 in stock
£342.22 ex VAT
£410.66 inc VAT
The ThinkVision P27q monitor has a black glossy appearance with a full function ergonomic stand. It offers a crystal clear borderless IPS display of 2560x1440 resolution and sRGB 99% color gamut, providing vivid, accurate images from a wide viewing angle. Moreover, each monitor has been pre-calibrated to obtain an accurate and consistent color with a factory calibration report. With built-in power and the rich connectivity of 2HDMI, DP, mDP and DP out, P27q satisfies diverse connection demand and can make multi-screen easier with daisy chain. P27q also has 4 USB3.0 ports, including 1 with BC1.2, which offers quick charge to your USB devices. Its full function stand supports lift, tilt, pivot and swivel, which are all for your ease of use.
Lenovo ThinkVision P27q-20 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Power Consumption (On mode)
18.8 W
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 6 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
99% BT.709, 99% sRGB, 85% DCI-P3
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Raven black
61.38 cm x 20.8 cm x 44.15 cm
7.12 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
CCC, RoHS, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
27"
Built-in Devices
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
60 Hz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Integrated cable management, Flicker Free technology, Low Blue Light technology, 4-side NearEdgeless, 99% sRGB colour gamut
Raven black
61.38 cm x 20.8 cm x 44.15 cm - with stand
7.12 kg
HDMI , DisplayPort , DisplayPort output , USB 3.1 Gen 1 upstream , 4 x USB 3.1 Gen 1 downstream , Headphones
Mechanical
Tilt Angle
-5/+35
Swivel Angle
90
Rotation Angle
180
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x Mini DisplayPort-DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
18.8 W
18.8 kWh/1000h
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand (lowest position) - width: 61.38 cm - depth: 20.8 cm - height: 44.15 cm - weight: 7.12 kg , With stand (highest position) - width: 61.38 cm - depth: 20.8 cm - height: 57.65 cm - weight: 7.12 kg , Without stand - width: 61.38 cm - depth: 4.69 cm - height: 35.38 cm - weight: 4.64 kg
Shipping Width
72.2 cm
Shipping Depth
18.2 cm
Shipping Height
46.3 cm
Shipping Weight
9.26 kg
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
FPV4 Lenovo Thinkvision MC50 Monitor Webcam In Stock £53.23
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: DisplayPort
Brand: Lenovo
Stock Status: In stock
