Lenovo ThinkVision P24q - LED monitor - 23.8" 23.8" 2560x1440
Quicklinx: FCM5WS00 Mfr#: 61A5GAT3UK
Diagonal Size: 23.8in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: None
Interfaces: DisplayPort, Mini DisplayPort, HDMI
£199.90 ex VAT
£239.88 inc VAT
The ThinkVision P24q monitor has a glossy appearance with a full function ergonomic stand. It offers a crystal clear borderless IPS display of high resolution and sRGB 99% color gamut, providing vivid, accurate images from a wide viewing angle. Moreover, each monitor has been pre-calibrated to obtain an accurate and consistent color with a factory calibration report. With built-in power and the rich connectivity of HDMI, DP, mDP and DP out, P24q satisfies diverse connection demand and can make multi-screen easier with daisy chain. Its full function stand supports lift, tilt, pivot and swivel, which are all for your ease of use.
LED-backlit LCD monitor - 23.8"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2058 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
14 ms (grey-to-grey); 6 ms; 4 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
54.02 cm x 26.175 cm x 37.34 cm
5.6 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, VESA FPMPMI, ISO 9241-307, GREENGUARD, DDC-2B/CI, UL Environmental SPC Gold, Directive 2002/95/EC, China Energy standard Tier 2, VESA TMDS, TUV Rheinland Eye Comfort Certification
3-year warranty
Display Type
Diagonal Size
23.8"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2058 mm
Pixel Per Inch
123.6
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 99 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
99% sRGB colour gamut, Mercury free, arsenic-free glass
54.02 cm x 26.175 cm x 37.34 cm - with stand
5.6 kg
2 x HDMI (HDCP) , DisplayPort (HDCP) , Mini DisplayPort (HDCP) , DisplayPort output , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
180
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), daisy chaining support
1 x Mini DisplayPort-DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
22 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Microsoft Windows 7, Windows 10
Dimensions & Weight Details
With stand - width: 54.02 cm - depth: 26.175 cm - height: 37.34 cm - weight: 5.6 kg , Without stand - width: 54.02 cm - depth: 4.2 cm - height: 32.598 cm - weight: 3.73 kg
ENERGY STAR Certified
Limited warranty - replacement - 3 years - carry-in
45 °C
10 - 80% (non-condensing)
Response Time: 4ms
Speakers: None
Interfaces: Mini DisplayPort
Interfaces: HDMI
Brand: Lenovo
