Lenovo ThinkVision P24h 23.8" 2560 x 1440 4ms HDMI LED Monitor
Quicklinx: D530WS00 Mfr#: 61AEGAT3UK
Diagonal Size: 23.8in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: None
Interfaces: DisplayPort, HDMI, USB-C
43 in stock
£223.34 ex VAT
£268.00 inc VAT
The ThinkVision P24h-10 monitor has a glossy appearance with a full-function ergonomic stand. It offers a crystal clear borderless IPS display of 2560 x 1440 resolution and sRGB 99% color gamut, providing vivid, accurate images from a wide viewing angle. Moreover, each monitor has been pre-calibrated to obtain an accurate and consistent color with a factory calibration report. With built-in power and the rich connectivity of USB-C, HDMI, DP and DP out, P24h-10 satisfies diverse connection demand and can make multi-screen easier with daisy chain. USB-C can offer one-cable connection usage experience to customers. P24h-10 also has 4 USB 3.0 ports. Its full-function stand supports lift, tilt, pivot and swivel, which are all for your ease of use.
Lenovo ThinkVision P24h-10 - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2058 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
14 ms (grey-to-grey); 6 ms; 4 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Raven black
54.02 cm x 26.175 cm x 37.34 cm
5.69 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
FCC Class B certified, ISO 9241-307, WEEE, DDC-2B/CI, Directive 2002/95/EC, China Energy standard Tier 2, VESA TMDS, TUV Rheinland Eye Comfort Certification
3-year warranty
Display Type
Diagonal Size
23.8"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2058 mm
Pixel Per Inch
124
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 99 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
OSD Languages
English, German, French, Italian, Russian, Spanish, Japanese, Chinese
99% sRGB colour gamut, integrated cable management, daisy chain compatible, Mercury free, arsenic-free glass, USB 3.0 Quick Charge, borderless
Raven black
54.02 cm x 26.175 cm x 37.34 cm - with stand
5.69 kg
2 x HDMI (HDCP) , DisplayPort (HDCP) , DisplayPort output , USB-C , 4 x USB 3.0 downstream , Audio line-out
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x USB-C cable - 1.8 m
24 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
With stand - width: 54.02 cm - depth: 26.175 cm - height: 37.34 cm - weight: 5.69 kg , Without stand - width: 54.02 cm - depth: 4.645 cm - height: 32.598 cm - weight: 3.82 kg
ENERGY STAR Certified
TCO Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
10 - 80% (non-condensing)
Lenovo ThinkVision P24h 23.8 Bundle deal on Lenovo ThinkVision P24h 23.8" 2560 x 1440 4ms HDMI LED Monitor
£322.51
D530 Lenovo Microsaver Security Cable Lock In Stock £23.76
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Interfaces: USB-C
Brand: Lenovo
Price Range Ex VAT: 150 - 300
