Brand
Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor
Quicklinx: FGLVWS00 Mfr#: 61DDUAT6UK
Diagonal Size: 14in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: None
Interfaces: DisplayPort, USB-C
17 in stock
£240.46 ex VAT
£288.55 inc VAT
Lenovo ThinkVision M14 - LED monitor - Full HD (1080p) - 14"
LED-backlit LCD monitor - 14"
Energy Consumption per Year
15.53 kWh
Power Consumption (On mode)
4.88 W
USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1611 mm
Brightness
300 cd/m²
Contrast Ratio
700:1 / 3000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
2xUSB-C
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
Voltage
Raven black
32.337 cm x 9.654 cm x 20.903 cm
0.57 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
CCC, RoHS, ISO 9241-307, Directive 2002/95/EC, China Energy standard Tier 2
3-year warranty
Display Type
15.53 kWh
Diagonal Size
14"
Viewable Size
14"
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1611 mm
Pixel Per Inch
157
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
72% NTSC (CIE 1931) colour gamut, Low Blue Light Mode, Mercury free, arsenic-free glass, Eye comfort mode, Eye-Care Technology, 8-bit + A-FRC Colour Depth
Raven black
32.337 cm x 9.654 cm x 20.903 cm - with stand
0.57 kg
2 x USB-C 3.1 Gen 1/DisplayPort Alt Mode with Power Delivery 2.0 (power up to 65W)
Mechanical
Height, tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Clips
1 x USB-C cable - 1 m
Security Slot Type
Kensington security slot
Input Voltage
4.88 W
Power Consumption (Typical)
6 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand (highest position) - width: 32.337 cm - depth: 9.654 cm - height: 22.003 cm - weight: 570 g , With stand (lowest position) - width: 32.337 cm - depth: 9.654 cm - height: 20.903 cm - weight: 570 g
Shipping Width
40.2 cm
Shipping Depth
27.6 cm
Shipping Height
6.1 cm
Shipping Weight
1.67 kg
ENERGY STAR Certified
ENERGY STAR Version
7.1
Limited warranty - 3 years
30 - 80%
Diagonal Size: 14in
Response Time: 6ms
Speakers: None
Interfaces: USB-C
Brand: Lenovo
Stock Status: In stock
