Brand
Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor
Quicklinx: FGLVWS00 Mfr#: 61DDUAT6UK
Diagonal Size: 14in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: None
Interfaces: DisplayPort, USB-C
45 in stock
£177.14 ex VAT
£212.56 inc VAT
  • Mobile display for the modern professional
    Looking to give yourself an edge when it comes to mobile productivity? Check out the ThinkVision M14. This ultraportable 14" FHD mobile display connects to your laptop via USB-C to give you extra screen real estate for your own work - and a great way to share content with clients and colleagues. Its ergonomic design lets you control the viewing angle - and thanks to ports on both sides, it's friendly to right- and left-handed users. It also comes with a durable sleeve for protection on the go. ThinkVision M14: The modern solution for mobile productivity.
  • Ultraslim, ultralight
    At just 598g and 4.4mm†, the ThinkVision M14 mobile display won't weigh you down. And despite its ultraportable design, it delivers great visuals on its FHD (1920 x 1080) IPS display.
  • Advanced connectivity
    The ThinkVision M14 mobile display features two advanced USB-C ports that simultaneously support power and video. Its "power pass through" design lets you charge both the ThinkVision M14 and your laptop with a single adapter. Be sure your laptop, tablet, or smartphone has a full-function USB-C connector that supports Display Port 1.2 Alt Mode and PD2.0.
  • Productivity plus flexibility
    The ThinkVision M14 mobile display's flexible design lets you work the way you want to. It has ports on both the right and left sides for easy alignment. The monitor has a -5° to 90° tilt angle and an adjustable foot lets you change the height to your liking. And it comes with its own protective sleeve for carefree travel. What's more, its advanced low-blue-light technology reduces eyestrain, taking some of the sting out of long workdays. Finally time to relax? Stream everything you like to the M14 from your phone, tablet, or laptop.
Lenovo ThinkVision M14 - LED monitor - Full HD (1080p) - 14"
LED-backlit LCD monitor - 14"
Energy Consumption per Year
15.53 kWh
Power Consumption (On mode)
4.88 W
USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1611 mm
Brightness
300 cd/m²
Contrast Ratio
700:1 / 3000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
2xUSB-C
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
Voltage
Raven black
32.337 cm x 9.654 cm x 20.903 cm
0.57 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
CCC, RoHS, ISO 9241-307, Directive 2002/95/EC, China Energy standard Tier 2
3-year warranty
Display Type
15.53 kWh
Diagonal Size
14"
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1611 mm
Pixel Per Inch
157
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Low Blue Light Mode, Mercury free, arsenic-free glass, Eye comfort mode, Eye-Care Technology, 8-bit + A-FRC Colour Depth
Raven black
32.337 cm x 9.654 cm x 20.903 cm - with stand
0.57 kg
2 x USB-C 3.1 Gen 1/DisplayPort Alt Mode with Power Delivery 2.0 (power up to 65W)
Mechanical
Height, tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Clips
1 x USB-C cable - 1 m
Security Slot Type
Kensington security slot
Input Voltage
4.88 W
Power Consumption (Typical)
6 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand (highest position) - width: 32.337 cm - depth: 9.654 cm - height: 22.003 cm - weight: 570 g , With stand (lowest position) - width: 32.337 cm - depth: 9.654 cm - height: 20.903 cm - weight: 570 g
Shipping Width
40.2 cm
Shipping Depth
27.6 cm
Shipping Height
6.1 cm
Shipping Weight
1.67 kg
ENERGY STAR Certified
ENERGY STAR Version
7.1
Limited warranty - 3 years
30 - 80%
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: FGLV 045721
Condition: Customer return - item has been used and shows signs of use. Item does not have a plug for the power lead.
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £152.57
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Diagonal Size: 14in
Response Time: 6ms
Speakers: None
Interfaces: USB-C
Brand: Lenovo
Stock Status: In stock
Stock Status: Used Stock
