Product
Lenovo ThinkVision LT2423 24" 1920 x 1080 5MS VGA+HDMI LED Monitor
Quicklinx: 91D6WS00 Mfr#: 60A8KAT2UK
Enjoy amazing value and uncompromising performance with ThinkVision LT2423 LCD Monitor. This monitor offers a brilliant and responsive 24-inch Full HD display which can maximize your viewing experience whether for work or play.
Its minimalistic design along with Tiny PC mounting support allow for a cleaner and a more simplified workspace to increase productivity. LT2423 also sports a powerful stereo speaker which delivers incredible sound quality. In addition, it adopts the latest green standards, meeting Energy Star 6.0, TUV Green Mark, EPEAT Gold, TCO Display 6.0, TCO Certified Edge 1.2, and UL Environment Gold; on top of this, it boasts lower energy consumption and lesser environmental impact.
Lenovo ThinkVision LT2423 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
27.8 kWh
Power Consumption (On mode)
19.01 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.278 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Speakers
Integrated
Display Position Adjustments
Tilt
Business black
56.71 cm x 21.67 cm x 41.43 cm
3.76 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, MPR II, VESA FPMPMI, RoHS, ISO 9241-307, WEEE, DDC-2B/CI, TCO Displays 6.0, UL Environmental SPC Gold, TCO Certified Edge 1.2
Display Type
Energy Class
Class A+
27.8 kWh
19.01 W
Diagonal Size
24"
Viewable Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.278 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Video Bandwidth
205 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Brightness, input select
HDCP, 72% colour gamut
Business black
3.76 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
VGA , HDMI , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
Stand
1 x VGA cable - 1.8 m
Mounting Kit
Optional
Security Slot Type
Kensington security slot
Power Supply
Internal
21 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Windows 8
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
91D6 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
91D6 C2G 5m Select High Speed HDMI with Ethernet In Stock £20.88
91D6 C2G 15m Select High Speed HDMI with Ethernet In Stock £54.29
91D6 C2G Pro HDMI to VGA Converter In Stock £50.07
