The ThinkVision LT2013s is a light, slim monitor that comfortably manages your workspace. Equipped with LED panel, tilt stand and VGA connectivity, this monitor delivers a reliable performance at an affordable price.
It also supports Tiny PC, third-party Thin Client and Lenovo USB Soundbar with ease.
- Lenovo ThinkVision LT2013s - LED monitor - 19.5"
- LED-backlit LCD monitor - 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.281 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1
- Response Time
- 5 ms
- Colour Gamut
- 72%
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Business black
- 46.7 cm x 16.07 cm x 34.24 cm
- 2.5 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- FCC Class B certified, CSA, BSMI, GOST, IEC950, NEMKO, NOM, SABS, SASO, VESA FPMPMI, VESA EDID, CB, CCC, PSB, IRAM, RoHS, ISO 9241-307, JEITA, KC, Kvalitet, KUCAS, DDC-2B/CI, BELLIS, INSM
- 3-year warranty
- Display Type
- Diagonal Size
- 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.281 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 50
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, input select
- Business black
- 2.5 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable - 1.8 m
- Mounting Kit
- Optional
- Localisation
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 17 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
- Microsoft Windows 7, Windows 8
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years - carry-in
