The Lenovo ThinkVision E2323 monitor meets users all functional needs in both work and home environments. It adopts WLED backlit panel, with wide screen of 1920 x 1080 resolution pixels, which provides Full HD qualification to customers. Its 16:9 aspect is standing for the increasingly popular trend. With built-in VGA + DVI interfaces and tiltable stand, it offers users comfortable usage experience. Compatible with Windows8.1 makes it more flexible for usage. In addition, it is environmentally conscious, meeting the latest green standards including Energy Star 6.0 Certified, TCO 6.0, China Energy Standard Tier1, EPEAT Silver Certification.
- Lenovo ThinkVision E2323 - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 3000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB (CIE 1931), 72% NTSC (CIE 1931)
- Input Connectors
- DVI, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- 54.85 cm x 16.72 cm x 39.9 cm
- 3.55 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- TUV Ergo, DDC/CI, RoHS, ISO 9241-307
- 3-year warranty
- Display Type
- Diagonal Size
- 23"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 205 MHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 50
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, H/V position, input select, colour temperature
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
- Raven black
- 3.55 kg
- VGA , DVI
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m
- Localisation
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 21 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - carry-in
- 0 °C
- 45 °C
- 10 - 80%
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
