Lenovo ThinkVision E2054 19.5" 1440x900 7ms VGA DVI LED Monitor
Quicklinx: CPKWWS00 Mfr#: 60DFAAT1UK
Diagonal Size: 19.5in
Max Resolution: 1440 x 900
Response Time: 7ms
Speakers: None
Interfaces: VGA (HD-15)
Hurry, only 1 left in stock!
£76.26 ex VAT
£91.51 inc VAT
ThinkVision E2054 19.5-inch LED Backlit LCD Monitor. The Lenovo ThinkVision E2054 monitor provides essential functionality for commercial users who balance between performance and value. With wide-viewing angle IPS panel, images are clear in 178°/178° angle. It is also designed to be compact and space-saving which supports Thinkcenter Tiny PC via VESA bracket mounting.
Lenovo ThinkVision E2054 - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1440 x 900
Pixel Pitch
0.097 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
7 ms (grey-to-grey)
Input Connectors
VGA
Display Position Adjustments
Tilt
Raven black
45.6 cm x 18.83 cm x 37.2 cm
2.18 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
FCC Class B certified, TUV, DDC-2B, VESA DPMS, DDC/CI, RoHS, ISO 9241-307, WEEE, Green Mark, CEL Grade 1, China RoHS, EDID compatible
3-year warranty
Display Type
Diagonal Size
19.5"
Viewable Size
19.5"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1440 x 900
Pixel Pitch
0.097 mm
Pixel Per Inch
87
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
7 ms (grey-to-grey)
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Brightness
HDCP, 72% colour gamut, Mercury free
Raven black
2.18 kg
VGA (HD-15)
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Stand
1 x VGA cable - VGA to VGA - 1.8 m
16 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
ENERGY STAR Certified
TCO Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
Lenovo ThinkVision E2054 19.5 Bundle deal on Lenovo ThinkVision E2054 19.5" 1440x900 7ms VGA DVI LED Monitor
£175.43
Response Time: 7ms
Speakers: None
Brand: Lenovo
Stock Status: Clearance
Price Range Ex VAT: 50 - 100
