ThinkVision E1922 is a commercial monitor which is targeted at the entry segment in a size of 18.5" and aims to offer the best value in 16:9/250 nits. With built-in VGA interface, it offers easy connection to PC. It is environmentally conscious, meeting the latest standards, including Energy Star 6.0, EPEAT Gold, TCO Display 6.0 and 85% PCC plastic resins. For space-saving, this monitor also supports the ThinkCentre Tiny PC with VESA mount at the back.
- Lenovo ThinkVision E1922 - LED monitor - 18.5"
- LED-backlit LCD monitor - 18.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768 at 60 Hz
- Pixel Pitch
- 0.3 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Tilt
- Business black
- 34.15 cm x 16.72 cm x 44.84 cm
- 2.74 kg
- Localisation
- English / United Kingdom
- CSA, TUV, BSMI, EN 60950, NEMKO, NOM, SASO, CB, CCC, RoHS, ISO 9241-307, JEITA, KC, EPA 6.0, ISC
- 3-year warranty
- Display Type
- Diagonal Size
- 18.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Vertical Refresh Rate
- 60 - 75 Hz
- Video Bandwidth
- 85.5 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness
- Business black
- 2.74 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Localisation
- Limited warranty - 3 years - carry-in
- 0 °C
- 40 °C
- 20 - 90%
