Your basket is empty
Lenovo ThinkVision E1922 18.5" 1366x768 5ms VGA DVI LED Monitor
Quicklinx: 9LX3WS00 Mfr#: 60B8AAT6UK
ThinkVision E1922 is a commercial monitor which is targeted at the entry segment in a size of 18.5" and aims to offer the best value in 16:9/250 nits. With built-in VGA interface, it offers easy connection to PC. It is environmentally conscious, meeting the latest standards, including Energy Star 6.0, EPEAT Gold, TCO Display 6.0 and 85% PCC plastic resins. For space-saving, this monitor also supports the ThinkCentre Tiny PC with VESA mount at the back.
Lenovo ThinkVision E1922 - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Display Position Adjustments
Tilt
Business black
34.15 cm x 16.72 cm x 44.84 cm
2.74 kg
English / United Kingdom
CSA, TUV, BSMI, EN 60950, NEMKO, NOM, SASO, CB, CCC, RoHS, ISO 9241-307, JEITA, KC, EPA 6.0, ISC
3 years warranty
Display Type
Diagonal Size
18.5"
Viewable Size
18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
60 - 75 Hz
Video Bandwidth
85.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Brightness
72% colour gamut
Business black
2.74 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
Limited warranty - 3 years - carry-in
20 - 90%
9LX3 C2G 2m DVI-A Male to HD15 VGA Male Analogue Video Cable In Stock £8.65
9LX3 C2G 2m Ultima™ HD15 Male to RCA HDTV Component Video Breakout Cable In Stock £8.65
9LX3 C2G 2m Premium HD15 Male to RGBHV (5-BNC) Male Video Cable In Stock £11.09
9LX3 C2G VGA to Composite PC-TV Video Adapter In Stock £29.72
