Lenovo ThinkStation P910 Tower Xeon E5-26250 4x8GB 256SSD Win10Pro
Quicklinx: CQ18WS00 Mfr#: 30B9000DUK
  • Xeon
Get extreme performance from this dual-processor workhorse, powered by powerful processors and amazing graphics and featuring the most I/O in the industry. Perfect for professionals running intensive apps in the engineering & architecture, media & entertainment, oil & gas, or medical industries.
  • Powerful performance
    Thanks to the increased performance of processors and amazing graphics, the ThinkStation P910 has the power and speed to handle your workload with ease.
  • Unparalleled versatility
    The ThinkStation P910 features a superior modular design, including Flex Trays holding up to two drives per bay and feature blind connection for cable-free versatility. Configure only the components you need, for the ultimate in usability and savings.
  • Steadfast reliability
    Tri-Channel Cooling ensures each component receives cool air, using an air baffle. The ThinkStation P910 uses fewer fans and stays cooler than the competition, so it continues to run for less downtime and a higher bottom line.
  • Ease of use
    Intuitive red touch points guide you to quick and easy component changes - even to the motherboard and swappable power supply - without having to use a single tool. And cable management means no wires or plugs, and superior serviceability.
Lenovo ThinkStation P910 - tower - Xeon E5-2620V4 2.1 GHz - 32 GB - SSD 256 GB
Workstation - tower
2 x Intel Xeon E5-2620V4 / 2.1 GHz (, up to 3 GHz, (8-core)
Processor Socket
LGA2011-v3 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
40 MB
Cache Per Processor
20 MB
RAM
32 GB (installed) / 512 GB (max) - DDR4 SDRAM - ECC - PC4-19200
Storage Controller
RAID (SATA 6Gb/s)
Hard Drive
SSD 256 GB - SATA 6Gb/s - TCG Opal Encryption
Optical Storage
DVD-Writer
Card Reader
9 in 1
Graphics Controller
No graphics
1GbE
OS Provided
Windows 10 Pro 64-bit Edition
20 cm x 62 cm x 44.6 cm
32.3 kg
Manufacturer Selling Program
TopSeller
Limited warranty - 3 years - response time: next business day
Workstation
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
2
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
40 MB
Cache Per Processor
20 MB
RAM
Installed Size
32 GB / 512 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
DIMM 288-pin
Slots
16 (Total) / 12 (empty)
Registered, mixing of different types of memory modules is not supported, slots 9 - 16 are available in two-processor configuration only
Configuration Features
4 x 8 GB
RAM Supported
512 GB registered , 896 GB Load-Reduced
Hard Drive
SSD
1 x 256 GB
Interface Type
SATA 6Gb/s
TCG Opal Encryption
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-Writer - SATA
Card Reader
9 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I218-LM, I210-AT
Wake on LAN (WoL)
Bays
3 (total) / 2 (free) x external 5.25" x 1/2H , 4 (total) / 3 (free) x internal 3.5"
Slots
16 (total) / 12 (free) x DIMM 288-pin , 2 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - full-length, full-height (2 processors must be installed) , 2 (total) / 2 (free) x PCIe 2.0 x1 - full-length, full-height , 2 (total) / 2 (free) x Flex Connector
8 x USB 3.0 (4 front, 4 rear) (one of them is Always On, one of them is Diagnostic) , 1 x headphones/microphone (1 in front) , 4 x USB 2.0 , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse
RoHS, GREENGUARD
TopSeller
Power supply
Power Provided
1300 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
92%
Operating System / Software
OS Provided
20 cm
62 cm
44.6 cm
32.3 kg
10 °C
35 °C
10 - 80% (non-condensing)
