Product
Lenovo ThinkStation P900 Tower Intel Xeon E5-2640v3 8GB 1TB Win 8.1
Quicklinx: BXQFWS00 Mfr#: 30A5000JUK
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
ThinkStation P900 delivers extreme performance, as well as high storage capacity. It also delivers great technologies and design to keep your workstation cool and quiet. Maximize productivity with independent display support for up to three independent monitors using Mosaic Mode with integrated powerful graphics. With USB 3.0 ports, you can move data quickly between your workstation and other devices. The ThinkStation P900 continues the long legacy of unmatched reliability touted by Lenovo single and dual processor workstations. It's built with the same efficient thermal design and employs a cooling process that makes ThinkStation workstations stand out from the competition.
  • Thermal design: elegant & efficient
    Patented tri-channel cooling with just 3 system fans and a direct cooling air baffle directs fresh air into the CPU and memory. ThinkStation P900 delivers great technologies and design to keep your workstation cool and quiet.
  • Improved design & functionality
    No more bulky handles, just a clean-looking, functional design. Integrated handles make it easier to carry and move the systems, or place into a rack.
  • Multiple monitor display
    Maximize productivity with independent display support for up to three independent monitors using Mosaic Mode with integrated powerful graphics. Plus, connect to up to 16 independent monitors with 1.2 stream cloning mode.
  • Fast data transfer
    With USB 3.0 ports, you can move data quickly between your workstation and other devices. SuperSpeed USB 3.0 enables fast file transfer, which allows for lightning-fast copying of large media files, as well as seamless connections between audio- and video-related devices.
  • Modular components & tool-free expandability
    Great modular design makes tool-less upgrades a snap, especially with Flex Trays for fully configurable storage and interchangeable power supplies and graphics cards — especially beneficial when working with multiple workstations.
  • Unmatched reliability
  • GREENGUARD certified
    ThinkStation P900 tower is GREENGUARD certified and features a fixed power supply unit (PSU) that's 1300W and efficient.
Lenovo ThinkStation P900 - tower - Xeon E5-2640V3 2.6 GHz - 8 GB - 1 TB
Workstation - tower
2 x Intel Xeon E5-2640V3 / 2.6 GHz (3.4 GHz) (8-core)
Processor Socket
LGA2011-v3 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
40 MB
Cache Per Processor
20 MB
RAM
8 GB (installed) / 512 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s)
Hard Drive
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Card Reader
9 in 1
Graphics Controller
No graphics
Audio Output
Stereo
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
20 cm x 62 cm x 44.6 cm
29.9 kg
Manufacturer Selling Program
TopSeller
Limited warranty - 3 years
Workstation
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
8-core
CPU Qty
2
Max CPU Qty
2
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
40 MB
Cache Per Processor
20 MB
RAM
Installed Size
8 GB / 512 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
1866 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
16 (Total) / 14 (empty)
Registered, mixing of different types of memory modules is not supported, 8-channel memory architecture
Configuration Features
2 x 4 GB
RAM Supported
512 GB registered , 1 TB Load-Reduced
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-Writer - SATA
Card Reader
9 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I217-LM, I210AT
Bays
3 (total) / 2 (free) x external 5.25" , 4 (total) / 3 (free) x internal 3.5" x 1/3H
Slots
16 (total) / 14 (free) x DIMM 288-pin , 2 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x1 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x4 - full-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height (2 processors must be installed)
8 x USB 3.0 (4 front, 4 rear) , 1 x headphones/microphone (1 in front) , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse , 4 x USB 2.0
1 USB 3.0 (Always On)
TopSeller
Power supply
Nominal Voltage
Power Provided
1300 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
92%
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
20 cm
62 cm
44.6 cm
29.9 kg
10 °C
35 °C
10 - 80% (non-condensing)
BXQF Lenovo Optical 3-button W/Mouse USB In Stock £13.60
