A next-generation workstation that's powerful enough for any job and reliable enough for mission-critical environments. Customise a ThinkStation P700 for the power, performance and usability you need, including the highest storage capacity available. Intelligent design features include new Flex Tray that holds up to two drives for total flexibility and patented Tri-Channel Cooling for enhanced reliability.
Thermal design
Elegant & efficient patented tri-channel cooling with just 3 system fans - as opposed to 10 that other workstations typically rely on - and a direct cooling air baffle directs fresh air into the CPU and memory. ThinkStation P700 delivers new technologies and design to keep your workstation cool and quiet. -
Improved design & functionality
The ThinkStations have been redesigned. No more bulky handles, just a clean-looking, functional design. Integrated handles make it easier to carry and move they systems, or place into a rack. -
Multiple monitor display
Maximize productivity with independent display support for up to three independent monitors using Mosaic Mode. Plus, connect to up to 16 independent monitors with 1.2 stream cloning mode. -
Fast data transfer
With USB 3.0 ports, you can move data quickly between your workstation and other devices. SuperSpeed USB 3.0 enables file transfer up to 10 times faster than previous USB technologies, which allows for lightning-fast copying of large media files, as well as seamless connections between audio- and video-related devices. Backward-compatible with USB 2.0 devices. -
Modular components & tool-free expandability
Innovative modular design makes tool-less upgrades a snap, especially with Flex Trays for fully configurable storage and interchangeable power supplies and graphics cards - especially beneficial when working with multiple workstations. -
Unmatched reliability
The ThinkStation P700 continues the long legacy of unmatched reliability touted by Lenovo single and dual processor workstations. It's built with the same efficient thermal design and employs a cooling process that makes ThinkStation workstations stand out from the competition.
- Lenovo ThinkStation P700 - tower - Xeon E5-2630V3 2.4 GHz - 32 GB - SSD 256 GB, HDD 2 TB
- Workstation - tower - 1 USB 3.0 (Always On)
- Localisation
- Processor
- 2 x Intel Xeon E5-2630V3 / 2.4 GHz (, up to 3.2 GHz, (8-core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 40 MB
- Cache Per Processor
- 20 MB
- RAM
- 32 GB (installed) / 384 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- RAID (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express 2.0 x4 - M.2
- Hard Drive (2nd)
- HDD 2 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- 9 in 1
- Graphics Controller
- No graphics
- Audio Output
- Stereo
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- 17.5 cm x 47 cm x 44 cm
- 23.7 kg
- Manufacturer Selling Program
- TopSeller
- Limited warranty - 3 years
- Workstation
- Product Form Factor
- Tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-2630V3
- Clock Speed
- 2.4 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 8-core
- CPU Qty
- 2
- Max CPU Qty
- 2
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 40 MB
- 20 MB
RAM
- Installed Size
- 32 GB / 384 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 12 (Total) / 8 (empty)
- Registered, mixing of different types of memory modules is not supported, slots 7 - 12 are available in two-processor configuration only
- Configuration Features
- 4 x 8 GB
- RAM Supported
- 384 GB registered - ECC , 768 GB Load-Reduced - ECC
Hard Drive
- SSD - M.2
- Capacity
- 1 x 256 GB
- Interface Type
Hard Drive (2nd)
- HDD
- Interface Class
- Serial ATA
- Capacity
- 1 x 2 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD-Writer - SATA
Card Reader
- 9 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Bays
- 2 (total) / 1 (free) x external 5.25" x 1/2H , 4 (total) / 3 (free) x internal 3.5" x 1/3H
- Slots
- 12 (total) / 8 (free) x DIMM 288-pin , 2 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (2 processors must be installed) , 1 (total) / 1 (free) x PCI - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height
- 8 x USB 3.0 (4 front, 4 rear) , 1 x headphones/microphone (1 in front) , 4 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 650 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 92%
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- 17.5 cm
- 47 cm
- 44 cm
- 23.7 kg
- 10 °C
- 35 °C
- 10 - 80% (non-condensing)
