Lenovo ThinkStation P700 Tower 2 x E5-2620 32GB 256M SSD Win 8.1
Quicklinx: BXQ8WS00 Mfr#: 30A9001QUK
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
A next-generation workstation that's powerful enough for any job and reliable enough for mission-critical environments. Customise a ThinkStation P700 for the power, performance and usability you need, including the highest storage capacity available. Intelligent design features include new Flex Tray that holds up to two drives for total flexibility and patented Tri-Channel Cooling for enhanced reliability.
  • Thermal design
    Elegant & efficient patented tri-channel cooling with just 3 system fans - as opposed to 10 that other workstations typically rely on - and a direct cooling air baffle directs fresh air into the CPU and memory. ThinkStation P700 delivers new technologies and design to keep your workstation cool and quiet.
  • Improved design & functionality
    The ThinkStations have been redesigned. No more bulky handles, just a clean-looking, functional design. Integrated handles make it easier to carry and move they systems, or place into a rack.
  • Multiple monitor display
    Maximize productivity with independent display support for up to three independent monitors using Mosaic Mode. Plus, connect to up to 16 independent monitors with 1.2 stream cloning mode.
  • Fast data transfer
    With USB 3.0 ports, you can move data quickly between your workstation and other devices. SuperSpeed USB 3.0 enables file transfer up to 10 times faster than previous USB technologies, which allows for lightning-fast copying of large media files, as well as seamless connections between audio- and video-related devices. Backward-compatible with USB 2.0 devices.
  • Modular components & tool-free expandability
    Innovative modular design makes tool-less upgrades a snap, especially with Flex Trays for fully configurable storage and interchangeable power supplies and graphics cards - especially beneficial when working with multiple workstations.
  • Unmatched reliability
    The ThinkStation P700 continues the long legacy of unmatched reliability touted by Lenovo single and dual processor workstations. It's built with the same efficient thermal design and employs a cooling process that makes ThinkStation workstations stand out from the competition.
Lenovo ThinkStation P700 - tower - Xeon E5-2620V3 2.4 GHz - 32 GB - SSD 256 GB, HDD 2 TB
Workstation - tower - 1 USB 3.0 (Always On)
2 x Intel Xeon E5-2620V3 / 2.4 GHz (, up to 3.2 GHz, (6-core)
Processor Socket
LGA2011-v3 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
30 MB
Cache Per Processor
15 MB
RAM
32 GB (installed) / 384 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s)
Hard Drive
SSD 256 GB - M.2
Hard Drive (2nd)
HDD 2 TB - SATA - 7200 rpm
Optical Storage
DVD-Writer
Card Reader
9 in 1
Graphics Controller
No graphics
Audio Output
Stereo
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
17.5 cm x 47 cm x 44 cm
23.7 kg
Manufacturer Selling Program
TopSeller
Limited warranty - 3 years
Workstation
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
2.4 GHz
Max Turbo Speed
3.2 GHz
Number of Cores
6-core
CPU Qty
2
Max CPU Qty
2
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
30 MB
Cache Per Processor
15 MB
RAM
Installed Size
32 GB / 384 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
1866 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
12 (Total) / 8 (empty)
Registered, mixing of different types of memory modules is not supported, slots 7 - 12 are available in two-processor configuration only
Configuration Features
4 x 8 GB
RAM Supported
384 GB registered - ECC , 768 GB Load-Reduced - ECC
Hard Drive
SSD - M.2
1 x 256 GB
Hard Drive (2nd)
HDD
Interface Class
Serial ATA
1 x 2 TB
Spindle Speed
7200 rpm
Storage Controller
1 x RAID - integrated
Controller Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-Writer - SATA
Card Reader
9 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Integrated
Ethernet Controller
Intel I217-LM
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 4 (total) / 3 (free) x internal 3.5" x 1/3H
Slots
12 (total) / 8 (free) x DIMM 288-pin , 2 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (2 processors must be installed) , 1 (total) / 1 (free) x PCI - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height
8 x USB 3.0 (4 front, 4 rear) , 1 x headphones/microphone (1 in front) , 4 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse
TopSeller
Power supply
Power Provided
650 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
92%
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
17.5 cm
47 cm
44 cm
23.7 kg
10 °C
35 °C
10 - 80% (non-condensing)
