From large workloads to multitasking, the compact ThinkStation P520c breezes through it all. With fast processing, graphics, storage, and memory, this configurable workstation is a solid workhorse.
Real power
For true processing power and fast visuals, power up the ThinkStation P520c. Fueled by modern processors and graphics, this compact workhorse can help you to get the job done, quickly and easily. -
Configurable and reliable
The P520c can be configured to meet your specific needs. However you configure your P520c, ThinkStation workstations are well known for their reliability. -
Enhanced flexible design
With M.2 PCIe solid state drive slots embedded on the motherboard, you can enjoy fast storage speeds. What's more, the front FLEX module gives you a range of options and flexibility, including a media card reader, optical drives, and a variety of additional front access I/O ports.
- Lenovo ThinkStation P520c - tower - Xeon W-2104 3.2 GHz - 16 GB - SSD 256 GB - UK
- Workstation - tower
- Localisation
- Processor
- 1 x Intel Xeon W-2104 / 3.2 GHz (Quad-Core)
- Cache Memory
- 8.25 MB
- Cache Per Processor
- 8.25 MB
- RAM
- 16 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC
- Storage Controller
- RAID (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s - 2.5" - TCG Opal Encryption
- Optical Storage
- No optical drive
- Card Reader
- 9 in 1
- Graphics Controller
- No graphics
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro for Workstations 64-bit Edition
- 17.5 cm x 42.6 cm x 37.6 cm
- 14.5 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- TCO Certified Desktops 8
- Limited warranty - 3 years - on-site - response time: next business day
- Workstation
- Product Form Factor
- Tower
- Embedded Security
- Trusted Platform Module (TPM 1.2 and TPM 2.0)
- Localisation
Processor / Chipset
- CPU
- Intel Xeon W-2104
- Clock Speed
- 3.2 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel C422
Cache Memory
- Installed Size
- 8.25 MB
- 8.25 MB
RAM
- Installed Size
- 16 GB / 256 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Registered, quad channel memory architecture
- Configuration Features
- 1 x 16 GB
Hard Drive
- SSD - 2.5"
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- No optical drive
Card Reader
- 9 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Wake on LAN (WoL), Intel Active Management Technology (AMT) 11
- Bays
- 2 (total) / 2 (free) x external 5.25" x 1/2H , 2 (total) / 1 (free) x internal 3.5"
- Slots
- 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (open ended) , 1 (total) / 1 (free) x PCIe 3.0 x4 - half-length, full-height (open ended) , 2 (total) / 2 (free) x M.2 Card
- 6 x USB 3.0 (2 front, 4 rear) , 1 x headphones (1 in front) , 2 x microphone (1 front, 1 rear) , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- RoHS, GREENGUARD
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 500 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 92%
Operating System / Software
- OS Provided
- Windows 10 Pro for Workstations 64-bit Edition English
- TCO Certified
- 17.5 cm
- 42.6 cm
- 37.6 cm
- 14.5 kg
- 10 °C
- 35 °C
- 10 - 80% (non-condensing)
Monitors (3)
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £202.02 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor | In Stock | £336.70 |
Keyboards and Mice (3)
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £41.29 |
Lenovo Professional Wireless Keyboard | In Stock | £53.47 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
Other bundles (3)
Lenovo Mini Displayport to Displayport Cable | In Stock | £15.46 |
Lenovo MiniDisplayPort to HDMI Cable | In Stock | £17.02 |
Kensington Security Cable Lock | In Stock | £23.65 |
