Lenovo ThinkStation P520 Intel Xeon W-2133 16GB 512GB SSD Windows 10 Professional 64-bit
Quicklinx: FPSXWS00 Mfr#: 30BE009EUK
  • Xeon
The ThinkStation P520 blends lightning-quick computing and professional graphics, perfectly. With cutting-edge storage, memory, and cooling, it can handle everything from huge workloads and complex modelling to virtual reality. It's also totally configurable and designed with performance, reliability, and energy efficiency in mind.
  • Designed for users, engineered for IT managers
    Powerful enough to render VR, this high-performance workstation lets you tap the speed and efficiency of Intel Xeon processing and NVIDIA Quadro graphics. It also comes with ISV certification from all the major vendors like Autodesk, Bentley, and Siemens. To learn more about ISV certification, click here. Easy to set up, deploy, and manage, the ThinkStation P520 endures rigorous testing in extreme environmental conditions. So you can count on its reliability and durability. And with an exceptional design and build quality, it gives you increased serviceability along with decreased downtime. A win for any organization. What's more, fine-tuning and optimizing system performance is a breeze. Simply download and run the Lenovo Performance Tuner and Lenovo Workstation Diagnostics apps.
  • Performance you can count on
    Fueled by powerful processors and graphics, the P520 delivers jaw-dropping performance and stunning visuals. Whether it's computer-aided drafting or 3D animation software, this 33 L workhorse can boost your creativity and productivity.
  • Configurable and reliable
    Your P520 can be configured to meet your specific needs. One thing you don't have to worry about is reliability, which is built in as standard on every ThinkStation.
  • Get more done, quickly and easily
    With patented Tri-Channel Cooling technology, the P520 manages internal air flow and power supply better than most workstations. As a result, it runs more smoothly and efficiently - even when handling large workloads. The P520 also supports RAID virtualization technology and has two M.2 PCIe SSD slots embedded in the motherboard, enabling you to enjoy blistering-fast storage speeds.
  • Hassle-free, tool-free
    Should you ever need to swap any components, there's no need to worry about tools and screws. Simply slide off the side panel and away you go.
  • Durable and flexible
    Like every ThinkStation before it, the P520 has undergone rigorous testing under extreme conditions. ISV-certified, it boasts error-correcting code memory, ensuring even greater accuracy and reliability. What's more, the front FLEX module gives you a range of options and flexibility, including a media card reader and blazing-fast Intel Thunderbolt 3 port.
Lenovo ThinkStation P520 - tower - Xeon W-2133 3.6 GHz - vPro - 16 GB - SSD 512 GB - UK
Workstation - tower
Platform Technology
Intel vPro Platform
1 x Intel Xeon W-2133 / 3.6 GHz (6-core)
Cache Memory
8.25 MB
Cache Per Processor
8.25 MB
RAM
16 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s); NVMe (PCI Express)
Hard Drive
SSD 512 GB - PCI Express - M.2 - TCG Opal Encryption, NVM Express (NVMe)
Optical Storage
DVD-Writer
Card Reader
Graphics Controller
No graphics
GigE
Keyboard
OS Provided
Windows 10 Pro for Workstations 64-bit Edition
16.5 cm x 46 cm x 44 cm
24 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
TCO Certified Desktops 8 EPEAT Silver
Limited warranty - 3 years - on-site - response time: next business day
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 1.2 and TPM 2.0)
Processor / Chipset
CPU
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel C422
Cache Memory
Installed Size
8.25 MB
Cache Per Processor
8.25 MB
RAM
Installed Size
16 GB / 256 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
8 (Total) / 7 (empty)
Registered, quad channel memory architecture
Configuration Features
1 x 16 GB
Hard Drive
SSD - M.2
1 x 512 GB
Interface Type
PCI Express
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Storage Controller (2nd)
1 x NVMe
PCI Express
RAID Level
RAID 0, RAID 1
Optical Storage
DVD-Writer - SATA
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Mouse Name
Lenovo Calliope Mouse
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), Intel Active Management Technology (AMT) 11
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 2 (total) / 2 (free) x internal 3.5"
Slots
2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height (double-width) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (open ended) , 2 (total) / 2 (free) x PCIe 3.0 x4 - half-length, full-height (open ended) , 1 (total) / 1 (free) x PCI - full-length, full-height , 2 (total) / 1 (free) x M.2 Card
8 x USB 3.1 Gen 1 (4 front, 4 rear) (one of them is 11W charging) , 1 x headphones/microphone (1 in front) , 1 x microphone , 1 x audio line-in , 1 x audio line-out , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x serial
Lock kit (common key)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
RoHS, GREENGUARD
TopSeller
Power supply
Power Provided
900 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
92%
Operating System / Software
OS Provided
Windows 10 Pro for Workstations 64-bit Edition English
TCO Certified
EPEAT Compliant
EPEAT Silver
16.5 cm
46 cm
44 cm
24 kg
10 °C
35 °C
10 - 80% (non-condensing)
Monitors (4)
FPSX Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor In Stock £201.00
FPSX Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor In Stock £454.54
FPSX Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor In Stock £336.70
FPSX Lenovo Tiny-in-One 22 21.5" 1920 x 1080 14ms Full HD LED monitor In Stock £246.91
Keyboards and Mice (4)
FPSX Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 In Stock £41.29
FPSX Lenovo Professional Wireless Keyboard In Stock £53.21
FPSX Lenovo Essential Wired Keyboard and Mouse Combo - UK English In Stock £25.39
FPSX Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed In Stock £23.88
Other bundles (5)
FPSX Lenovo Mini Displayport to Displayport Cable In Stock £15.46
FPSX Lenovo MiniDisplayPort to HDMI Cable In Stock £17.02
FPSX Kensington Security Cable Lock In Stock £23.65
FPSX Lenovo 100 Headset on ear wired - USB black for IdeaPad 3 ThinkCe In Stock £35.79
FPSX Lenovo Thinkvision MC50 Monitor Webcam In Stock £52.71
