The ThinkStation P520 blends lightning-quick computing and professional graphics, perfectly. With cutting-edge storage, memory, and cooling, it can handle everything from huge workloads and complex modelling to virtual reality. It's also totally configurable and designed with performance, reliability, and energy efficiency in mind.
Designed for users, engineered for IT managers
Powerful enough to render VR, this high-performance workstation lets you tap the speed and efficiency of Intel Xeon processing and NVIDIA Quadro graphics. It also comes with ISV certification from all the major vendors like Autodesk, Bentley, and Siemens. To learn more about ISV certification, click here. Easy to set up, deploy, and manage, the ThinkStation P520 endures rigorous testing in extreme environmental conditions. So you can count on its reliability and durability. And with an exceptional design and build quality, it gives you increased serviceability along with decreased downtime. A win for any organization. What's more, fine-tuning and optimizing system performance is a breeze. Simply download and run the Lenovo Performance Tuner and Lenovo Workstation Diagnostics apps. -
Performance you can count on
Fueled by powerful processors and graphics, the P520 delivers jaw-dropping performance and stunning visuals. Whether it's computer-aided drafting or 3D animation software, this 33 L workhorse can boost your creativity and productivity. -
Configurable and reliable
Your P520 can be configured to meet your specific needs. One thing you don't have to worry about is reliability, which is built in as standard on every ThinkStation. -
Get more done, quickly and easily
With patented Tri-Channel Cooling technology, the P520 manages internal air flow and power supply better than most workstations. As a result, it runs more smoothly and efficiently - even when handling large workloads. The P520 also supports RAID virtualization technology and has two M.2 PCIe SSD slots embedded in the motherboard, enabling you to enjoy blistering-fast storage speeds. -
Hassle-free, tool-free
Should you ever need to swap any components, there's no need to worry about tools and screws. Simply slide off the side panel and away you go. -
Durable and flexible
Like every ThinkStation before it, the P520 has undergone rigorous testing under extreme conditions. ISV-certified, it boasts error-correcting code memory, ensuring even greater accuracy and reliability. What's more, the front FLEX module gives you a range of options and flexibility, including a media card reader and blazing-fast Intel Thunderbolt 3 port.
- Lenovo ThinkStation P520 - tower - Xeon W-2125 4 GHz - 16 GB - SSD 512 GB - UK
- Workstation - tower
- Localisation
- Processor
- 1 x Intel Xeon W-2125 / 4 GHz (Quad-Core)
- Processor Socket
- FCLGA2066 Socket
- Cache Memory
- 8.25 MB
- Cache Per Processor
- 8.25 MB
- RAM
- 16 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC
- Storage Controller
- RAID (SATA 6Gb/s)
- Hard Drive
- SSD 512 GB - SATA 6Gb/s - 2.5" - TCG Opal Encryption 2
- Optical Storage
- DVD-Writer
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro for Workstations 64-bit Edition
- 16.5 cm x 46 cm x 44 cm
- 24 kg
- Environmental Standards
- TCO Certified Desktops 8
- Limited warranty - 3 years - on-site
- Workstation
- Product Form Factor
- Tower
- Embedded Security
- Trusted Platform Module (TPM 1.2 and TPM 2.0)
- Localisation
Processor / Chipset
- CPU
- Intel Xeon W-2125 / 4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- FCLGA2066 Socket
- Chipset Type
- Intel C422
Cache Memory
- Installed Size
- 8.25 MB
- 8.25 MB
RAM
- Installed Size
- 16 GB / 256 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 8 (Total) / 7 (empty)
- Registered, quad channel memory architecture
- Configuration Features
- 1 x 16 GB
Hard Drive
- SSD - 2.5"
- Capacity
- 1 x 512 GB
- Manufacturer
- SanDisk
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD-Writer
Monitor
- Monitor Type
- None.
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- Lenovo Calliope Mouse
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Wake on LAN (WoL), Intel Active Management Technology (AMT) 11
- Bays
- 2 (total) / 1 (free) x external 5.25" x 1/2H , 2 (total) / 1 (free) x internal 3.5"
- Slots
- 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height (double-width) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (open ended) , 2 (total) / 2 (free) x PCIe 3.0 x4 - half-length, full-height (open ended) , 1 (total) / 1 (free) x PCI - full-length, full-height , 2 (total) / 2 (free) x M.2 Card
- 8 x USB 3.0 (4 front, 4 rear) (one of them is 11W charging) , 1 x headphones/microphone (1 in front) , 1 x microphone , 1 x audio line-in , 1 x audio line-out , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x PS/2 keyboard , 1 x PS/2 mouse
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- RoHS, GREENGUARD
- Power supply
- Voltage Required
- Power Provided
- 900 Watt
- Efficiency
- 92%
Operating System / Software
- OS Provided
- Windows 10 Pro for Workstations 64-bit Edition English
- TCO Certified
- 16.5 cm
- 46 cm
- 44 cm
- 24 kg
- 10 °C
- 35 °C
- 10 - 80% (non-condensing)
Monitors (5)
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £202.02 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor | In Stock | £336.70 |
Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor | In Stock | £321.24 |
Lenovo Tiny-in-One 22 21.5" 1920 x 1080 14ms Full HD LED monitor | In Stock | £246.91 |
Keyboards and Mice (3)
Lenovo Professional Wireless Keyboard | In Stock | £53.47 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed | In Stock | £23.88 |
Other bundles (5)
Lenovo Mini Displayport to Displayport Cable | In Stock | £15.46 |
Lenovo MiniDisplayPort to HDMI Cable | In Stock | £17.02 |
Kensington Security Cable Lock | In Stock | £23.65 |
Lenovo 100 Headset on ear wired - USB black for IdeaPad 3 ThinkCe | In Stock | £34.84 |
Lenovo Thinkvision MC50 Monitor Webcam | In Stock | £54.13 |
