Lenovo ThinkStation P520 Intel Xeon W-2104 16GB 256GB SSD Windows 10 Professional 64-bit
Quicklinx: FGJVWS00 Mfr#: 30BE006UUK
  • Xeon
The P520 delivers peak performance for architects, designers, engineers and creative professionals, pushing the limits of 3D animation and visual effects. With super-fast memory, cutting-edge storage, dual M.2 support directly on the motherboard, ISV certification and advanced cooling, it handles everything with ease-from huge workloads to complex modelling to virtual reality.
  • Designed for users, engineered for IT managers
    Powerful enough to render VR, this high-performance workstation lets you tap the speed and efficiency of Intel Xeon processing and NVIDIA Quadro graphics. It also comes with ISV certification from all the major vendors like Autodesk, Bentley, and Siemens. To learn more about ISV certification, click here. Easy to set up, deploy, and manage, the ThinkStation P520 endures rigorous testing in extreme environmental conditions. So you can count on its reliability and durability. And with an exceptional design and build quality, it gives you increased serviceability along with decreased downtime. A win for any organization. What's more, fine-tuning and optimizing system performance is a breeze. Simply download and run the Lenovo Performance Tuner and Lenovo Workstation Diagnostics apps.
  • Performance you can count on
    Fueled by powerful processors and graphics, the P520 delivers jaw-dropping performance and stunning visuals. Whether it's computer-aided drafting or 3D animation software, this 33 L workhorse can boost your creativity and productivity.
  • Configurable and reliable
    Your P520 can be configured to meet your specific needs. One thing you don't have to worry about is reliability, which is built in as standard on every ThinkStation.
  • Get more done, quickly and easily
    With patented Tri-Channel Cooling technology, the P520 manages internal air flow and power supply better than most workstations. As a result, it runs more smoothly and efficiently - even when handling large workloads. The P520 also supports RAID virtualization technology and has two M.2 PCIe SSD slots embedded in the motherboard, enabling you to enjoy blistering-fast storage speeds.
  • Hassle-free, tool-free
    Should you ever need to swap any components, there's no need to worry about tools and screws. Simply slide off the side panel and away you go.
  • Durable and flexible
    Like every ThinkStation before it, the P520 has undergone rigorous testing under extreme conditions. ISV-certified, it boasts error-correcting code memory, ensuring even greater accuracy and reliability. What's more, the front FLEX module gives you a range of options and flexibility, including a media card reader and blazing-fast Intel Thunderbolt 3 port.
Lenovo ThinkStation P520 - tower - Xeon W-2104 3.2 GHz - 16 GB - SSD 256 GB - UK
Workstation - tower
1 x Intel Xeon W-2104 / 3.2 GHz (Quad-Core)
Processor Socket
FCLGA2066 Socket
Cache Memory
8.25 MB
Cache Per Processor
8.25 MB
RAM
16 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s)
Hard Drive
SSD 256 GB - SATA 6Gb/s - 2.5" - TCG Opal Encryption
Optical Storage
DVD-Writer
Card Reader
9 in 1
Graphics Controller
No graphics
1GbE
Keyboard
OS Provided
Windows 10 Pro for Workstations 64-bit Edition
16.5 cm x 46 cm x 44 cm
24 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
TCO Certified Desktops 8
Limited warranty - 3 years - on-site - response time: next business day
Workstation
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 1.2 and TPM 2.0)
Processor / Chipset
CPU
Intel Xeon W-2104
Clock Speed
3.2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
FCLGA2066 Socket
Chipset Type
Intel C422
Cache Memory
Installed Size
8.25 MB
Cache Per Processor
8.25 MB
RAM
Installed Size
16 GB / 256 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
8 (Total) / 7 (empty)
Registered, quad channel memory architecture
Configuration Features
1 x 16 GB
Hard Drive
SSD - 2.5"
1 x 256 GB
Interface Type
SATA 6Gb/s
TCG Opal Encryption
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-Writer
Card Reader
9 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), Intel Active Management Technology (AMT) 11
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 2 (total) / 1 (free) x internal 3.5"
Slots
2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height (double-width) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (open ended) , 2 (total) / 2 (free) x PCIe 3.0 x4 - half-length, full-height (open ended) , 1 (total) / 1 (free) x PCI - full-length, full-height , 2 (total) / 2 (free) x M.2 Card
8 x USB 3.0 (4 front, 4 rear) (one of them is 11W charging) , 1 x headphones/microphone (1 in front) , 1 x microphone , 1 x audio line-in , 1 x audio line-out , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
RoHS, GREENGUARD
TopSeller
Power supply
Power Provided
900 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
92%
Operating System / Software
OS Provided
Sustainability Information
TCO Certified
16.5 cm
46 cm
44 cm
24 kg
10 °C
35 °C
10 - 80% (non-condensing)
Monitors (5)
FGJV Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor In Stock £201.00
FGJV Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor In Stock £454.54
FGJV Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor In Stock £336.70
FGJV Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor In Stock £314.26
FGJV Lenovo Tiny-in-One 22 21.5" 1920 x 1080 14ms Full HD LED monitor In Stock £246.91
Keyboards and Mice (4)
FGJV Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 In Stock £41.29
FGJV Lenovo Professional Wireless Keyboard In Stock £53.21
FGJV Lenovo Essential Wired Keyboard and Mouse Combo - UK English In Stock £26.08
FGJV Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed In Stock £23.88
Other bundles (11)
FGJV Lenovo Mini Displayport to Displayport Cable In Stock £15.46
FGJV Lenovo MiniDisplayPort to HDMI Cable In Stock £17.02
FGJV APC Smart-UPS C LCD AC 230 V - 900 Watt - 1500VA USB In Stock £593.78
FGJV APC Smart - UPS 1500VA LCD - SMT1500IC In Stock £629.55
FGJV Kensington Security Cable Lock In Stock £23.65
FGJV APC Smart UPS SRT 1000VA In Stock £883.28
FGJV APC BACK UPS PRO BR1600MI 1600VA 8 Outlets In Stock £343.33
FGJV Lenovo 100 Headset on ear wired - USB black for IdeaPad 3 ThinkCe In Stock £35.79
FGJV APC SMART-UPS SRT 1500VA 230V In Stock £1,167.56
FGJV APC SMART-UPS SRT 1000VA RM 230V In Stock £1,069.29
FGJV Lenovo Thinkvision MC50 Monitor Webcam In Stock £52.71
