Lenovo ThinkStation P500 Tower Intel Xeon E5-1650 4GB 256GB SSD W7P
Quicklinx: BXQ5WS00 Mfr#: 30A7000GUK
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
A next-generation workstation that's powerful enough for any job and reliable enough for mission-critical environments. Customise a ThinkStation P500 for the power, performance and usability you need, including the highest storage capacity available. Intelligent design features include new Flex Tray that holds up to two drives for total flexibility and patented Tri-Channel Cooling for enhanced reliability.
  • Thermal design
    ThinkStation P500 delivers technologies and design to keep your workstation cool and quiet.
  • Multiple monitor display
    Maximize productivity with independent display support for independent monitors using Mosaic Mode with integrated graphics.
  • Fast data transfer
    With USB 3.0 ports, you can move data quickly between your workstation and other devices. SuperSpeed USB 3.0 enables file transfer faster than previous USB technologies, which allows for lightning-fast copying of large media files, as well as seamless connections between audio- and video-related devices.
  • Modular components
    Innovative modular design makes tool-less upgrades a snap, especially with Flex Trays for fully configurable storage and interchangeable power supplies and graphics cards - especially beneficial when working with multiple workstations.
  • Unmatched reliability
    The ThinkStation P500 continues the long legacy of unmatched reliability touted by Lenovo single and dual processor workstations. It's built with the same efficient thermal design and employs a cooling process that makes ThinkStation workstations stand out from the competition.
  • Green Leadership
    ThinkStation P500 tower is Greenguard certified and features a fixed power supply unit.
Lenovo ThinkStation P500 - tower - Xeon E5-1650V3 3.5 GHz - 4 GB - SSD 256 GB
Workstation - tower - 1 USB 3.0 (Always On)
1 x Intel Xeon E5-1650V3 / 3.5 GHz (, up to 3.8 GHz, (6-core)
Processor Socket
LGA2011-v3 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
4 GB (installed) / 128 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s)
Hard Drive
SSD 256 GB - SATA 6Gb/s
Optical Storage
DVD-Writer
Card Reader
9 in 1
Graphics Controller
PCIe - NVIDIA Quadro K2200
Video Memory
4 GB
Audio Output
Stereo - integrated
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
17.5 cm x 47 cm x 44 cm
22.2 kg
Manufacturer Selling Program
TopSeller
Limited warranty - 3 years
Workstation
Product Form Factor
Tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.5 GHz
Max Turbo Speed
3.8 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
4 GB / 128 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
8 (Total) / 7 (empty)
Registered, quad channel memory architecture, mixing of different types of memory modules is not supported
Configuration Features
1 x 4 GB
RAM Supported
128 GB registered - ECC , 256 GB Load-Reduced - ECC
Hard Drive
SSD
1 x 256 GB
Interface Type
SATA 6Gb/s
TCG Opal Encryption
Storage Controller
1 x RAID - integrated
Controller Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-Writer
Card Reader
9 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Plug-in card
Interface Type
PCIe
Graphics Processor
NVIDIA Quadro K2200
Video Memory
4 GB
Video Interfaces
DVI, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
High Definition Audio
Integrated
Ethernet Controller
Intel I217-LM
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 4 (total) / 3 (free) x internal 3.5" x 1/3H
Slots
8 (total) / 7 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x4 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x1 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height
8 x USB 3.0 (4 front, 4 rear) , 1 x headphones/microphone (1 in front) , 1 x microphone , 4 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x DisplayPort , 1 x DVI-I (dual link)
TopSeller
Power supply
Power Provided
490 Watt
80 PLUS Certification
80 PLUS Gold
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
17.5 cm
47 cm
44 cm
22.2 kg
10 °C
35 °C
10 - 80% (non-condensing)
