The P330 Tiny workstation delivers the performance and speed to power through tasks - powerful processing combines blazing-fast memory with dual M.2 storage support. Plus, the P330 Tiny is primed for security with data encryption through TPM and a door to internal components that physically locks. The ThinkStation P330 Tiny workstation fits just about anywhere and can be positioned horizontally or vertically. Mount it on a wall, behind a monitor, or under a desk. You can even keep this tiny workstation on a bookshelf, as this device goes wherever you want it to.
IT departments can expect more
The P330 Tiny workstation delivers the performance and speed to power through tasks - powerful processing combines blazing-fast memory with dual M.2 storage support. Plus, the P330 Tiny is primed for security with data encryption through TPM and a door to internal components that physically locks. -
Adaptable by design
The ThinkStation P330 Tiny workstation fits just about anywhere and can be positioned horizontally or vertically. Mount it on a wall, behind a monitor, or under a desk. You can even keep this tiny workstation on a bookshelf, as this device goes wherever you want it to. -
Let your eyes run wild
This workstation supports up to six independent displays. You can use these professional graphics and rest assured that with Independent Software Vendor (ISV) certifications, your biggest challenge may just be which monitor to watch.
- Lenovo ThinkStation P330 - tiny - Core i9 9900T 2.1 GHz - 16 GB - SSD 512 GB - UK
- Workstation - tiny
- Localisation
- Processor
- 1 x Intel Core i9 (9th Gen) 9900T / 2.1 GHz (4.4 GHz) (8-core)
- Cache Memory
- 16 MB
- Cache Per Processor
- 16 MB
- RAM
- 16 GB DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 512 GB - PCI Express - M.2 - TCG Opal Encryption, NVM Express (NVMe)
- Optical Storage
- No optical drive
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Controller
- NVIDIA Quadro P1000 / Intel UHD Graphics 630
- Video Memory
- 4 GB GDDR5 SDRAM
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 17.9 cm x 18.29 cm x 3.65 cm
- 1.4 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Workstation
- Product Form Factor
- Tiny
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Core i9 (9th Gen) 9900T
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 4.4 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel Q370
Cache Memory
- Installed Size
- 16 MB
- 16 MB
RAM
- Installed Size
- 16 GB
- Technology
- DDR4 SDRAM - non-ECC
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 16 GB
Hard Drive
- SSD - M.2
- Capacity
- 1 x 512 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Video Interfaces
- HDMI, DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- Lenovo Calliope Mouse
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-AC 9560
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
- Wake on LAN (WoL), Intel Active Management Technology (AMT) 12
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 3 (total) / 1 (free) x M.2 Card , 1 (total) / 0 (free) x PCIe 3.0 x16 - low-profile (x8 mode)
- 3 x USB 3.1 Gen 1 (1 front, 2 rear) (one of them is charging) , 1 x USB-C Gen 1 (1 in front) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 2 x USB-C 3.1 Gen 2 , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x HDMI , 4 x Mini DisplayPort
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion switch
- Security Slot Type
- Kensington security slot
- RoHS, GREENGUARD
- TopSeller
- Power adapter
- Voltage Required
- Power Provided
- 135 Watt
- Efficiency
- 88%
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 17.9 cm
- 18.29 cm
- 3.65 cm
- 1.4 kg
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
Monitors (3)
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £201.00 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor | In Stock | £336.70 |
Keyboards and Mice (3)
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £41.29 |
Lenovo Professional Wireless Keyboard | In Stock | £53.21 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
Other bundles (4)
Lenovo Mini Displayport to Displayport Cable | In Stock | £15.46 |
Lenovo MiniDisplayPort to HDMI Cable | In Stock | £17.02 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.07 |
Kensington Security Cable Lock | In Stock | £23.65 |
