The ThinkStation P300 entry-level workstation boasts an intuitive purposeful design that delivers unprecedented flexibility. The redesigned chassis no longer features a bulky handle, but rather intuitive red touch points and extended lip in the front and the back for easy carrying and deployment. Additionally, the new FLEX module gives users the option to add only the components they need, allowing customized productivity-boosting configurations with added cost savings for vertical workflows. The FLEX module supports a combination of an ultra-slim optical drive, 29-in-1 media card reader, IEEE 1394 FireWire, and eSATA. Lenovo P300 is equipped with a fast processor and ECC memory support for improved productivity and reliability.
Tower workstation
Tower workstations provide the ultimate performance with full-featured scalability, yet are sized at just 25 liters. -
Improved design and functionality
No more bulky handles, just a clean-looking, functional design. An extended lip on the top lid that includes a red touch point, combined with a ledge on the back-side, make the P300 exceptionally easy to lift and carry. -
Multiple monitor display
Maximize productivity with independent display support for up to three independent monitors using mosaic mode with integrated Intel graphics. -
Fast data transfer
With 6 USB 3.0 ports (two in the front and four in the rear), plus 3 USB 2.0 (one internal), you can move data quickly between your workstation and other devices. SuperSpeed USB 3.0 enables file transfer up to 10 times faster than previous USB technologies, which allows for lightning-fast copying of large media files, as well as seamless connections between audio- and video-related devices. -
Unmatched reliability
The ThinkStation P300 continues the long legacy of unmatched reliability touted by Lenovo single and dual processor workstations. It's built with the same efficient thermal design and employs a cooling process that makes ThinkStation workstations stand out from the competition. -
Green leadership
ThinkStation P300 tower is GREENGUARD certified and features a fixed power supply unit (PSU) that's 450 W and up to 92% efficient.
- Lenovo ThinkStation P300 - tower - Xeon E3-1246V3 3.5 GHz - 8 GB - HDD 500 GB
- Workstation - tower - chassis intrusion detection
- Localisation
- Processor
- 1 x Intel Xeon E3-1246V3 / 3.5 GHz (, up to 3.9 GHz, (Quad-Core)
- Processor Socket
- LGA1150 Socket
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- RAID (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- 9 in 1
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Controller
- PCIe x16 - NVIDIA Quadro K600 / Intel HD Graphics P4600
- Video Memory
- 1 GB
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- Raven black
- 17.5 cm x 42.6 cm x 37.6 cm
- 13 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Workstation
- Product Form Factor
- Tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Raven black
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E3-1246V3
- Clock Speed
- 3.5 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel C226
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total) / 2 (empty)
- Unbuffered, dual channel memory architecture, mixing of different types of memory modules is not supported
- Configuration Features
- 2 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x RAID - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD-Writer - SATA
Card Reader
- 9 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Plug-in card
- Interface Type
- PCIe x16
- Graphics Processor
- Video Memory
- 1 GB
- Video Interfaces
- VGA, DVI, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- High Definition Audio
- Integrated
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Bays
- 2 (total) / 1 (free) x external 5.25" x 1/2H , 2 (total) / 1 (free) x internal 3.5" x 1/3H
- Slots
- 4 (total) / 2 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 0 (free) x PCIe 3.0 x16 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCI - half-length, full-height
- 2 x USB 2.0 (2 rear) , 2 x microphone - mini-jack (1 front, 1 rear) , 1 x headphones - mini-jack (1 in front) , 6 x USB 3.0 (2 front, 4 rear) , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x VGA , 3 x DisplayPort , 1 x DVI-I (dual link)
- Chassis intrusion detection
- RoHS, GREENGUARD
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 280 Watt
- 80 PLUS Certification
- 80 PLUS Bronze
- Efficiency
- 85%
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Sustainability Information
- ENERGY STAR Certified
- 17.5 cm
- 42.6 cm
- 37.6 cm
- 13 kg
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
