Lenovo ThinkStation P300 Tower Intel Xeon E3-1246v3 8GB 500GB Windows 7 Professional 64-bit
Quicklinx: 9TKCWS00 Mfr#: 30AH0018UK
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
The ThinkStation P300 entry-level workstation boasts an intuitive purposeful design that delivers unprecedented flexibility. The redesigned chassis no longer features a bulky handle, but rather intuitive red touch points and extended lip in the front and the back for easy carrying and deployment. Additionally, the new FLEX module gives users the option to add only the components they need, allowing customized productivity-boosting configurations with added cost savings for vertical workflows. The FLEX module supports a combination of an ultra-slim optical drive, 29-in-1 media card reader, IEEE 1394 FireWire, and eSATA. Lenovo P300 is equipped with a fast processor and ECC memory support for improved productivity and reliability.
  • Tower workstation
    Tower workstations provide the ultimate performance with full-featured scalability, yet are sized at just 25 liters.
  • Improved design and functionality
    No more bulky handles, just a clean-looking, functional design. An extended lip on the top lid that includes a red touch point, combined with a ledge on the back-side, make the P300 exceptionally easy to lift and carry.
  • Multiple monitor display
    Maximize productivity with independent display support for up to three independent monitors using mosaic mode with integrated Intel graphics.
  • Fast data transfer
    With 6 USB 3.0 ports (two in the front and four in the rear), plus 3 USB 2.0 (one internal), you can move data quickly between your workstation and other devices. SuperSpeed USB 3.0 enables file transfer up to 10 times faster than previous USB technologies, which allows for lightning-fast copying of large media files, as well as seamless connections between audio- and video-related devices.
  • Unmatched reliability
    The ThinkStation P300 continues the long legacy of unmatched reliability touted by Lenovo single and dual processor workstations. It's built with the same efficient thermal design and employs a cooling process that makes ThinkStation workstations stand out from the competition.
  • Green leadership
    ThinkStation P300 tower is GREENGUARD certified and features a fixed power supply unit (PSU) that's 450 W and up to 92% efficient.
Lenovo ThinkStation P300 - tower - Xeon E3-1246V3 3.5 GHz - 8 GB - HDD 500 GB
Workstation - tower - chassis intrusion detection
1 x Intel Xeon E3-1246V3 / 3.5 GHz (, up to 3.9 GHz, (Quad-Core)
Processor Socket
LGA1150 Socket
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
RAID (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Card Reader
9 in 1
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Controller
PCIe x16 - NVIDIA Quadro K600 / Intel HD Graphics P4600
Video Memory
1 GB
Audio Output
Stereo - integrated
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Raven black
17.5 cm x 42.6 cm x 37.6 cm
13 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Workstation
Product Form Factor
Tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Raven black
Processor / Chipset
CPU
Clock Speed
3.5 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1150 Socket
Chipset Type
Intel C226
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total) / 2 (empty)
Unbuffered, dual channel memory architecture, mixing of different types of memory modules is not supported
Configuration Features
2 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x RAID - integrated
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-Writer - SATA
Card Reader
9 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Plug-in card
Interface Type
PCIe x16
Graphics Processor
Video Memory
1 GB
Video Interfaces
VGA, DVI, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
High Definition Audio
Integrated
Ethernet Controller
Intel I217-LM
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 2 (total) / 1 (free) x internal 3.5" x 1/3H
Slots
4 (total) / 2 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 0 (free) x PCIe 3.0 x16 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCI - half-length, full-height
2 x USB 2.0 (2 rear) , 2 x microphone - mini-jack (1 front, 1 rear) , 1 x headphones - mini-jack (1 in front) , 6 x USB 3.0 (2 front, 4 rear) , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x VGA , 3 x DisplayPort , 1 x DVI-I (dual link)
Chassis intrusion detection
RoHS, GREENGUARD
TopSeller
Power supply
Power Provided
280 Watt
80 PLUS Certification
80 PLUS Bronze
Efficiency
85%
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Sustainability Information
ENERGY STAR Certified
17.5 cm
42.6 cm
37.6 cm
13 kg
9TKC C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
