Lenovo ThinkSmart Hub 500 for Zoom i5-7500T 8GB 128GB SSD W10 IoT
Quicklinx: FPSRWS00 Mfr#: 10V50006UK
  • Core i5
  • IEEE 802.11n
Say hello to ThinkSmart Hub 500. Easy to deploy and use, this all-in-one, purpose-built Skype Room Systems device is the key to more efficient meetings. Start on time, every time with one tap of your finger. Hear what everyone has to say, loud and clear. And see the difference this makes to your productivity - and bottom line.
  • Because everyone's time is valuable
    Meetings are time consuming enough without trying to get the technology to work properly. The average delay is around 10 minutes, but with the ThinkSmart Hub 500, you can avoid costly late starts. As audio and video is already connected, simply hit one button and everyone can begin collaborating right away.
  • A better way for teams to work together
    A key feature of the ThinkSmart Hub 500 is its eye-catching anti-glare, anti-smudge display. Rotatable through 360°, anyone within arm reach can take and give control instantly, enabling meetings to run more smoothly - and more fairly. There's also a 3-color LED ring that lets everyone in the room know the status of the call.
  • Simplify meetings, worldwide
    Whether you're a host or attendee, the ThinkSmart Hub 500 will make your life easier. Eeveryone in your organization will be familiar with the system wherever your business takes them.
Lenovo ThinkSmart Hub 500 - for Zoom Rooms - all-in-one - Core i5 7500T 2.7 GHz - 8 GB - SSD 128 GB - LED 11.6"
Personal computer - all-in-one
Bundled Services
3 Years Lenovo Premier Support
Intel Core i5 (7th Gen) 7500T / 2.7 GHz (3.3 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB DDR4 SDRAM
Hard Drive
SSD 128 GB - PCI Express 3.0 x2 - M.2 2242
Optical Storage
No optical drive
Monitor
11.6" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
Graphics Controller
Intel HD Graphics 630
GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1
OS Provided
Windows 10 IoT Enterprise SAC 64-bit Edition
Business black
19.325 cm x 27.89 cm x 17.845 cm
2.5 kg
Limited warranty - 3 years - on-site
Personal computer
Bundled Services
Product Form Factor
All-in-one
Built-in Devices
Stereo speakers, 3-colour LED ring
Sensors
Presence sensor
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Business black
Processor / Chipset
CPU
Clock Speed
2.7 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel Q270
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 0 (empty)
Dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
SSD - M.2 2242
1 x 128 GB
Manufacturer
Western Digital
Interface Type
PCI Express 3.0 x2
Optical Storage
No optical drive
Monitor
Monitor Type
LED
Touchscreen
Yes (10-point multi-touch)
Diagonal Size
11.6"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Image Contrast Ratio
800:1
Monitor Features
Anti-glare, Wide Viewing Angle, 360° rotatable, smudge resistant
Graphics Controller
Graphics Processor
Video Interfaces
HDMI
Audio Output
Dolby Audio Premium
Speakers Included
2 x right / left channel
Audio Input
Two microphones
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
Wake on LAN (WoL)
Slots
2 (total) / 0 (free) x M.2 Card
4 x USB 3.1 Gen 1 , 1 x HDMI input , 2 x HDMI output , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), secure cable management door
Security Slot Type
Kensington security slot
RoHS, WEEE, GREENGUARD, Energy-Related Products (ErP) Lot 26
Power adapter
Power Provided
90 Watt
Efficiency
88%
Operating System / Software
OS Provided
Windows 10 IoT Enterprise SAC 64-bit Edition English
19.325 cm
27.89 cm
17.845 cm
2.5 kg
FPSR Lenovo HDMI to VGA Monitor Adapter In Stock £23.20
FPSR Lenovo 2m HDMI Cable In Stock £17.02
FPSR Kensington Security Cable Lock In Stock £23.65
