The ThinkServer TD350 combines the latest Intel Xeon performance, with legendary Think quality and excellent systems management capabilities to deliver a high performance, maximum storage density design, great for SMB, mid-market and remote offices. TD350 is a dual-socket tower server providing full enterprise capabilities in a 4U tower form factor. With up to 32 processor cores and 90 TB of storage, the TD350 is ideal for SMB and large enterprise applications. A complete portfolio of systems management tools increases uptime and productivity while keeping costs low. Enhanced hardware monitoring, alerts and diagnostics combined with integrated provisioning and deployment tools make TD350 the ultimate solution for any environment. Think Enterprise Engineered for maximum performance and storage capacity, ideal for small and medium business.
Right-sized computing for optimal performance
The ThinkServer TD350 allows you to balance high performance and massive storage capacity without the need to invest in a rack infrastructure. With innovative engineering, this 4U tower server offers 25 percent more hard disk drives per 1U, including faster file transfers and IOPs performance. Plus, two additional enterprise-class M.2 solid-state drives are available as an internal option for secure booting. All of these features, ultimately, translate to better value for your business! -
Compatible in any environment
Remote access and open industry standards mean ThinkServer TD350 is an ideal tower server for any environment - whether it's needed in tower form for front office or rack-mounted for growing data center use. The design is Energy Star-compliant, offers high-efficiency PSU options to lower operating expenses, and boasts continuous operation at 45 degrees Celsius without any time restrictions and with no impact on reliability. Plus, with easy setup and whisper-quiet acoustics at just 37 decibels, the TD350 immediately and quietly delivers all the power of an enterprise rack server in the compact footprint of a tower. -
Designed to scale with your business
Configuration flexibility makes TD350 highly adaptable. Internal expandability allows it to grow with your business demands over time, so you get excellent investment protection - better total cost of ownership and better return on investment. Installation and upgrade are a cynch with tool-less access to 95 percent of all customer replaceable parts. Grow from 5 non-hot-swap SATA drives and 2 built-in NIC ports to 32 hot-swap drives, hardware RAID, and multiple 10 Gb NIC ports in a snap. Your small business can initially invest in TD350 to support simple file/print with applicable hosting, and then easily scale to support more complex business analytics and large databases.
- Lenovo ThinkServer TD350 - tower - Xeon E5-2640V3 2.6 GHz - 8 GB - no HDD
- Server - tower - administrator password, power-on password
- Height (Rack Units)
- 4U
- Localisation
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2640V3 / 2.6 GHz (, up to 3.4 GHz, (8-core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 20 MB
- Cache Per Processor
- 20 MB
- RAM
- 8 GB (installed) / 512 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) (ThinkServer RAID 720ix AnyRAID)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD-Writer
- Graphics Controller
- ASPEED AST2400
- Video Memory
- 16 MB
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- No operating system
- 25.1 cm x 68.6 cm x 45.9 cm
- 22 kg
- Manufacturer Selling Program
- TopSeller
- Limited warranty - 3 years - on-site
- Server
- Product Form Factor
- Tower - 4U
- 2-way
- Front Accessible Bays Qty
- 2
- Hot-Swap Bays Qty
- 15
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-2640V3
- Clock Speed
- 2.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 20 MB
- 20 MB
RAM
- Installed Size
- 8 GB / 512 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 16 (Total) / 15 (empty)
- Registered, Memory Mirroring, Memory Sparing, mixing of different types of memory modules is not supported, 8-channel memory architecture
- Configuration Features
- 1 x 8 GB
- RAM Supported
- 512 GB registered - ECC , 1024 GB Load-Reduced - ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- ThinkServer RAID 720ix AnyRAID
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
- Buffer Size
- 1 GB
Optical Storage
- DVD-Writer
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- ASPEED AST2400
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Ethernet Ports
- 2 x Gigabit Ethernet
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- Aspeed AST2400
- Bays
- 2 (total) / 1 (free) x external 5.25" x 1/2H , 15 (total) / 15 (free) x hot-swap 3.5"
- Slots
- 16 (total) / 15 (free) x DIMM 288-pin , 2 (total) / 1 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (2 processors must be installed) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode, 2 processors must be installed) , 3 (total) / 3 (free) x PCIe 3.0 x16 - half-length, full-height (x8 mode, 2 processors must be installed)
- 4 x USB 3.0 , 1 x serial , 1 x VGA , 2 x LAN (Gigabit Ethernet) , 1 x management - RJ-45 , 2 x USB 2.0
- Administrator password, power-on password
- TopSeller
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 750 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
Operating System / Software
- OS Provided
- 25.1 cm
- 68.6 cm
- 45.9 cm
- 22 kg
- 10 °C
- 45 °C
- 20 - 80% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
