Enjoy ultimate flexibility with the enterprise-class, 1U, single-socket ThinkServer RS140 rack server. This compact form factor has a 16.2" deep chassis and features outstanding support for embedded graphics CPUs.
How is Lenovo ThinkServer RS140 versatile for business? It's loaded with features, gives you the choice of a dual-chassis, and has a slim, 1U design. The RS140 runs a range of operating systems, including client OS capability for retail applications. It's among the quietest models in the industry, and it features easy-to-use, industry-standard management tools.
Powerful support for graphics-enabled CPU
Intel Xeon processor supports more HD transcodes concurrently, per rack, than some discrete graphics solutions, which translates to high performance and high image quality. -
Versatile for business
How is Lenovo ThinkServer RS140 versatile for business? It's loaded with features, gives you the choice of a dual-chassis, and has a slim, 1U design. The RS140 runs a range of operating systems, including client OS capability for retail applications. It's among the quietest models in the industry, and it features easy-to-use, industry-standard management tools. -
Built-in value
Lenovo aims to add value to your business by including features you need without a lot of the unnecessary extras. Lenovo ThinkServer RS140 is an affordable, entry-level rack server ideal for small- to medium-sized business, workgroups, distributed locations, and webscale workloads. Plus the RS140 features integrated NICs, and an x8 PCIe slot for RAID protection, network expansion, or SSD cache acceleration to better protect your valuable data. -
Smart and easy server management
Intel's Advanced Management Technology (AMT) offers an easy-to-use management tool for remote diagnostics, updates, and repairs - regardless of platform state. AMT provides OS graceful shutdown to help prevent data corruption at the application and file system level, while also improving power-management features. Plus you get enhanced KVM support for up to 2560 x 1600 resolutions and a broad management-console ecosystem support.
- Lenovo ThinkServer RS140 - rack-mountable - Xeon E3-1226V3 3.3 GHz - 4 GB - no HDD
- Server - rack-mountable - administrator password, power-on password
- Height (Rack Units)
- 1U
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E3-1226V3 / 3.3 GHz (, up to 3.7 GHz, (Quad-Core)
- Processor Socket
- LGA1150 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC
- Hard Drive
- No HDD
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel HD Graphics P4600
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- No operating system
- Black
- 43 cm x 41.1 cm x 4.35 cm
- 7.35 kg
- Limited warranty - 1 year - on-site
- Server
- Product Form Factor
- Rack-mountable - 1U
- Built-in Devices
- Led panel
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 1-way
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 1
- Black
Processor / Chipset
- CPU
- Intel Xeon E3-1226V3
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel C226
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1600 MHz
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total)
- Unbuffered, dual channel memory architecture
Hard Drive
- No HDD
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel I210
- Data Link Protocol
- Bays
- 4 (total) / 4 (free) x simple-swap SAS - 2.5" , 1 (total) / 0 (free) x external 5.25"
- Slots
- 4 DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 PCIe 3.0 x8 - half-length, full-height
- 4 x USB 2.0 (2 front, 2 rear) , 4 x USB 3.0 , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management , 1 x VGA , 1 x DisplayPort
- Administrator password, power-on password
- Power supply
- Voltage Required
- Power Provided
- 350 Watt
- 80 PLUS Certification
- 80 PLUS Gold
Operating System / Software
- OS Provided
- 43 cm
- 41.1 cm
- 4.35 cm
- 7.35 kg
- 10 °C
- 35 °C
- 10 - 80% (non-condensing)
C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable | In Stock | £26.51 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £15.80 |
