Tremendous internal storage capacity and more I/O connectivity than ever before is the result of an innovative design on the new ThinkServer RD650. With up to 26 drive bays and vast internal storage capacity, the RD650 is great for storage-hungry applications such as databases, data analytics clusters, and video streaming. Up to eight PCIe slots give you plenty of bandwidth to scale your I/O. Plus, for ultimate performance, the industry-unique Lenovo AnyBay design allows multiple storage types in the same drive bay, including front-accessible PCIe SSD.
Highly flexible design
The latest Intel Xeon processors, large memory capacity, and loads of storage, combined with multiple chassis types, RAID choices, make it easy to create the perfect RD650 configuration to run your business-critical applications. Leveraging the Lenovo AnyFabric and AnyRAID designs, the RD650 can house up to four 10Gb Ethernet ports and your choice of RAID adapter without taking up any of the available PCIe slots. -
Extra-reliable performance
Data center cooling costs can be greater than the cost of powering the IT equipment itself. One way to reduce these cooling costs is by operating the data center at a higher temperature. With a dynamic environmental design, the RD650 can run continuously at 45 degrees Celsius - with no impact on reliability. In fact, the system has been carefully architected and tested to support long-term reliability. The RD650 is also perfect for organizations that install servers in less strictly controlled environments. Other high-reliability features include error correcting code (ECC) memory, hot-swap hard-disk drive and SSD capability, and hot-swap and redundant power and cooling.
- Lenovo ThinkServer RD650 - rack-mountable - Xeon E5-2630V3 2.4 GHz - 8 GB - no HDD
- Server - rack-mountable - administrator password, power-on password
- Height (Rack Units)
- 2U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2630V3 / 2.4 GHz (, up to 3.2 GHz, (8-core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 20 MB
- Cache Per Processor
- 20 MB
- RAM
- 8 GB (installed) / 384 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) (ThinkServer RAID 720ix AnyRAID)
- Server Storage Bays
- Hot-swap 2.5", 3.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- ASPEED AST2400
- Video Memory
- 16 MB
- Networking
- 10 GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- No operating system
- 48.2 cm x 76.4 cm x 8.7 cm
- 16 kg
- Manufacturer Selling Program
- TopSeller
- Limited warranty - parts and labour - 3 years - on-site
- Server
- Product Form Factor
- Rack-mountable - 2U
- Built-in Devices
- Led panel
- 2-way
- Hot-Swap Bays Qty
- 15
Processor / Chipset
- CPU
- Intel Xeon E5-2630V3
- Clock Speed
- 2.4 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 20 MB
- 20 MB
RAM
- Installed Size
- 8 GB / 384 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, Memory Mirroring, Memory Sparing, mixing of different types of memory modules is not supported, 8-channel memory architecture
- Configuration Features
- 1 x 8 GB
- RAM Supported
- 384 GB registered - ECC , 768 GB Load-Reduced - ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - plug-in card
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- ThinkServer RAID 720ix AnyRAID
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
- Buffer Size
- 1 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- ASPEED AST2400
- Video Memory
- 16 MB
- Video Interfaces
- DisplayPort
- Ethernet Ports
- 4 x 10 Gigabit Ethernet
- Data Link Protocol
- 10 Gigabit Ethernet
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- Aspeed AST2400
- Bays
- 6 (total) / 6 (free) x hot-swap 2.5" , 9 (total) / 9 (free) x hot-swap 3.5"
- Slots
- 24 (total) / 23 (free) x DIMM 288-pin , 2 (total) / 1 (free) x CPU , 3 (total) / 3 (free) x PCIe 3.0 x8 - half-length, full-height , 3 (total) / 3 (free) x PCIe 3.0 x8 - low-profile (2 processors must be installed)
- 2 x USB 3.0 (2 rear) , 1 x DisplayPort , 1 x serial , 4 x LAN (10Gigabit Ethernet) - RJ-45 , 1 x management - RJ-45
- Administrator password, power-on password
- TopSeller
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 750 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
Operating System / Software
- OS Provided
- 48.2 cm
- 76.4 cm
- 8.7 cm
- 16 kg
- 10 °C
- 45 °C
- 20 - 80% (non-condensing)
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
