Lenovo ThinkServer RD650 Intel Xeon E5-2630v3 8GB
Quicklinx: B061WS00 Mfr#: 70D2001HEA
  • Xeon
Tremendous internal storage capacity and more I/O connectivity than ever before is the result of an innovative design on the new ThinkServer RD650. With up to 26 drive bays and vast internal storage capacity, the RD650 is great for storage-hungry applications such as databases, data analytics clusters, and video streaming. PCIe slots give you plenty of bandwidth to scale your I/O. Plus, for ultimate performance, the industry-unique Lenovo AnyBay design allows multiple storage types in the same drive bay, including front-accessible PCIe SSD.
  • Highly flexible design
    The latest Intel Xeon processors, large memory capacity, and loads of storage, combined with multiple chassis types, RAID choices, and I/O options, make it easy to create the perfect RD650 configuration to run your business-critical applications. In addition to the standard 3.5- and 2.5-inch chassis, the RD650 offers a unique hybrid option with nine 3.5-inch and six 2.5- inch drive bays in the front and two 2.5-inch drive bays in the back - great for creating a tiered storage environment. Leveraging the Lenovo AnyFabric and AnyRAID designs, the RD650 can house up to four 10Gb Ethernet ports and your choice of RAID adapter without taking up any of the available PCIe slots.
  • Extra-reliable performance
    Data center cooling costs can be greater than the cost of powering the IT equipment itself. One way to reduce these cooling costs is by operating the data center at a higher temperature. With a dynamic environmental design, the RD650 can run continuously at 45 degrees Celsius - with no impact on reliability. In fact, the system has been carefully architected and tested to support long-term reliability. The RD650 is also perfect for organizations that install servers in less strictly controlled environments. Other high-reliability features include error correcting code (ECC) memory, hot-swap hard-disk drive and SSD capability, and hot-swap and redundant power and cooling.
Lenovo ThinkServer RD650 - rack-mountable - Xeon E5-2630V3 2.4 GHz - 8 GB - no HDD
Server - rack-mountable - administrator password, power-on password
Height (Rack Units)
2U
Server Scalability
2-way
1 x Intel Xeon E5-2630V3 / 2.4 GHz (, up to 3.2 GHz, (8-core)
Processor Socket
LGA2011-v3 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
20 MB
Cache Per Processor
20 MB
RAM
8 GB (installed) / 384 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) (ThinkServer RAID 720ix AnyRAID)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
ASPEED AST2400
Video Memory
16 MB
10 GigE
Power Redundancy
Optional
OS Provided
No operating system
48.2 cm x 76.4 cm x 8.7 cm
16 kg
Manufacturer Selling Program
TopSeller
Limited warranty - parts and labour - 3 years - on-site
Server
Product Form Factor
Rack-mountable - 2U
Built-in Devices
Led panel
Server Scalability
2-way
Hot-Swap Bays Qty
24
Processor / Chipset
CPU
Clock Speed
2.4 GHz
Max Turbo Speed
3.2 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
20 MB
Cache Per Processor
20 MB
RAM
Installed Size
8 GB / 384 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
1866 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, Memory Mirroring, Memory Sparing, mixing of different types of memory modules is not supported, 8-channel memory architecture
Configuration Features
1 x 8 GB
RAM Supported
384 GB registered - ECC , 768 GB Load-Reduced - ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - plug-in card
Controller Interface Type
Storage Controller Name
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
1 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
ASPEED AST2400
Video Memory
16 MB
Video Interfaces
DisplayPort
Ethernet Ports
4 x 10 Gigabit Ethernet
10 Gigabit Ethernet
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Aspeed AST2400
Bays
24 (total) / 24 (free) x hot-swap 2.5"
Slots
24 (total) / 23 (free) x DIMM 288-pin , 2 (total) / 1 (free) x CPU , 3 (total) / 3 (free) x PCIe 3.0 x8 - half-length, full-height , 3 (total) / 3 (free) x PCIe 3.0 x8 - low-profile (2 processors must be installed)
2 x USB 3.0 (2 rear) , 2 x DisplayPort (1 front, 1 rear) , 1 x serial , 4 x LAN (10Gigabit Ethernet) - RJ-45 , 1 x management - RJ-45 , 2 x USB 2.0 (2 in front)
Administrator password, power-on password
TopSeller
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
750 Watt
80 PLUS Certification
80 PLUS Platinum
Operating System / Software
OS Provided
No operating system
48.2 cm
76.4 cm
8.7 cm
16 kg
10 °C
45 °C
20 - 80% (non-condensing)
B061 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £12.92
