Innovation is built in to the new Lenovo ThinkServer RD550. A cleverly engineered design allows more storage density and I/O connectivity than ever before - giving you the performance and capacity of a 2U system in a 1U form factor. By creating smaller drive trays and a slightly larger chassis within the same 1U space, the RD550 offers a total of up to 12 bays, which can be used for data storage or better performance. Industry-unique Lenovo AnyBay design allows multiple storage types in the same drive bay, including front-accessible PCIe SSD for ultimate performance.
Highly flexible I/O
In the past, 1U servers were constrained by their size and did not have as many I/O slots as larger servers. With the new RD550, networking configurations that traditionally required a larger server can now fit into a 1U form factor. Leveraging the unique Lenovo AnyFabric design, the RD550 can house up to eight 10 Gb Ethernet ports - without taking up any of the available PCIe slots. If you include network adapters in the available slots, the RD550 can support an incredible amount of network bandwidth in a single 1U server. -
Extra-reliable performance
Data center cooling costs can be greater than the cost of powering the IT equipment itself. One way to reduce these cooling costs is by operating the data center at a higher temperature. With a dynamic environmental design, the RD550 can run at 45 degrees Celsius continuously - with no impact on reliability. In fact, the system has been carefully architected and tested to support long-term reliability. The RD550 is also perfect for organizations that install servers in less strictly controlled environments. Other high-reliability features include ECC memory, hot-swap hard-disk drive and SSD capability, and hot-swap and redundant power and cooling.
- Lenovo ThinkServer RD550 - rack-mountable - Xeon E5-2620V3 2.4 GHz - 8 GB - no HDD
- Server - rack-mountable - administrator password, power-on password
- Height (Rack Units)
- 1U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2620V3 / 2.4 GHz (, up to 3.2 GHz, (6-core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 15 MB
- Cache Per Processor
- 15 MB
- RAM
- 8 GB (installed) / 384 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) (ThinkServer RAID 720ix AnyRAID)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- ASPEED AST2400
- Video Memory
- 16 MB
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- No operating system
- 48.2 cm x 78 cm x 4.3 cm
- 13.5 kg
- Manufacturer Selling Program
- TopSeller
- Limited warranty - parts and labour - 3 years - on-site
- Server
- Product Form Factor
- Rack-mountable - 1U
- Built-in Devices
- Led panel
- 2-way
- Hot-Swap Bays Qty
- 12
Processor / Chipset
- CPU
- Intel Xeon E5-2620V3
- Clock Speed
- 2.4 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 15 MB
- 15 MB
RAM
- Installed Size
- 8 GB / 384 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, Memory Mirroring, Memory Sparing, mixing of different types of memory modules is not supported, 8-channel memory architecture
- Configuration Features
- 1 x 8 GB
- RAM Supported
- 384 GB registered - ECC , 768 GB Load-Reduced - ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - plug-in card
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- ThinkServer RAID 720ix AnyRAID
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
- Buffer Size
- 1 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- ASPEED AST2400
- Video Memory
- 16 MB
- Video Interfaces
- DisplayPort
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- Aspeed AST2400
- Bays
- 12 (total) / 12 (free) x hot-swap 2.5"
- Slots
- 24 (total) / 23 (free) x DIMM 288-pin , 2 (total) / 1 (free) x CPU , 2 (total) / 2 (free) x PCIe 3.0 x8 - low-profile
- 2 x USB 3.0 (2 rear) , 1 x DisplayPort , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x management - RJ-45
- Administrator password, power-on password
- TopSeller
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 750 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
Operating System / Software
- OS Provided
- 48.2 cm
- 78 cm
- 4.3 cm
- 13.5 kg
- 10 °C
- 45 °C
- 20 - 80% (non-condensing)
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
