The Lenovo ThinkServer RD450 boasts up to two processors. With loads of memory via 16 slots, there is a tremendous increase in capacity. Because the RD450 uses the DDR4 memory, you get a great boost in performance and an increase in power savings - enabling your applications to run faster and more efficiently. This makes it perfect for your infrastructure, collaboration and line-of-business applications, as well as web-serving or hosting.
Unrivaled performance
The Lenovo ThinkServer RD450 boasts up to two processors. With loads of memory via 16 slots, there is a tremendous increase in capacity. Because the RD450 uses the DDR4 memory, you get a great boost in performance and an increase in power savings - enabling your applications to run faster and more efficiently. This makes it perfect for your infrastructure, collaboration and line-of-business applications, as well as web-serving or hosting. -
Plenty of storage
The Lenovo ThinkServer RD450 is a dual-socket, 2U server that offers flexible configuration possibilities to create the right system for your needs. If you're a small- to medium-sized business, this server is ideal because of its large, cost-effective storage capacity. The ThinkServer RD450 2.5" configuration leverages the Lenovo AnyRAID design, allowing the use of your choice of RAID adapter without taking up a PCIe slot. -
Less to manage
A key feature of the RD450 and all ThinkServer systems is its use of open industry standards and protocols, so it integrates seamlessly into your multi-vendor environment. That means you can use your existing management tools with the RD450. The RD450 offers a suite of intuitive lifecycle tools that make management easy, so you can focus on IT projects that drive your business. These tools include configuration, deployment and power-planning tools, as well as a tool for energy management.
- Lenovo ThinkServer RD450 - rack-mountable - Xeon E5-2630V3 2.4 GHz - 8 GB - no HDD
- Server - rack-mountable - administrator password, power-on password, chassis intrusion detection
- Height (Rack Units)
- 2U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2630V3 / 2.4 GHz (, up to 3.2 GHz, (8-core)
- Cache Memory
- 20 MB
- Cache Per Processor
- 20 MB
- RAM
- 8 GB (installed) / 512 GB (max) - DDR4 SDRAM - ECC
- Storage Controller
- SAS (SATA 6Gb/s / SAS 6Gb/s) (ThinkServer RAID 500)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD-Writer
- Graphics Controller
- ASPEED AST2400
- Video Memory
- 16 MB
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- No operating system
- 48.2 cm x 76.4 cm x 8.7 cm
- 16 kg
- Manufacturer Selling Program
- TopSeller
- Limited warranty - 1 year - on-site - response time: next business day
- Server
- Product Form Factor
- Rack-mountable - 2U
- Built-in Devices
- Led panel
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 2-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 8
Processor / Chipset
- CPU
- Intel Xeon E5-2630V3
- Clock Speed
- 2.4 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
Cache Memory
- Installed Size
- 20 MB
- 20 MB
RAM
- Installed Size
- 8 GB / 512 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 1866 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 16 (Total) / 15 (empty)
- Registered, Memory Mirroring, Memory Sparing, mixing of different types of memory modules is not supported, 8-channel memory architecture
- Configuration Features
- 1 x 8 GB
- RAM Supported
- 512 GB registered - ECC , 1024 GB Load-Reduced - ECC
Hard Drive
- No HDD
Storage Controller
- 1 x SAS
- Controller Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Storage Controller Name
- ThinkServer RAID 500
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- ASPEED AST2400
- Video Memory
- 16 MB
- Video Interfaces
- DisplayPort
- Integrated
- Data Link Protocol
- Gigabit Ethernet
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- ThinkServer System Manager (TSM)
- Bays
- 8 (total) / 8 (free) x hot-swap 3.5" , 1 (total) / 0 (free) x external 5.25"
- Slots
- 16 (total) / 15 (free) x DIMM 288-pin , 2 (total) / 1 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, low-profile (x8 mode, 2 processors must be installed) , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height
- 2 x USB 2.0 (2 in front) , 1 x DisplayPort , 1 x VGA , 2 x USB 3.0 , 1 x management - RJ-45 , 2 x LAN (Gigabit Ethernet) , 1 x serial
- Included Accessories
- Rack sliding rails
- Administrator password, power-on password, chassis intrusion detection
- TopSeller
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 750 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
Operating System / Software
- OS Provided
- 48.2 cm
- 76.4 cm
- 8.7 cm
- 16 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable | In Stock | £32.58 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.82 |
