Product
Brand
Lenovo ThinkServer 3.5 INCH 1TB 7.2K SATA Hard Drive
Quicklinx: B9QWWS00 Mfr#: 0C19502
This 7200 RPM 3.5-inch enterprise-class SATA 6 Gbps hard drive provides you with the high reliability and SATA 7200 RPM performance for your ThinkServer solution. ThinkServer 3.5 inch 7.2K RPM enterprise-class SATA drive is the perfect 3.5 inch hard drive for demanding business environments that require highly reliable and efficient high capacity storage, such as for external and internal storage, backups and archival applications. This high-capacity drive provides the ultra low cost per gigabyte to the customers.
Lenovo Enterprise Direct Connect - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
ThinkServer TD340 (3.5"); TS140; TS440 (3.5")
1 TB
3.5"
SATA 6Gb/s
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Lenovo ThinkServer TD340 (3.5") , Lenovo ThinkServer TS140 , Lenovo ThinkServer TS440 (3.5")
