Your basket is empty
Lenovo ThinkServer 2.5 300GB 10K SAS 6Gb Hot Swap Hard Drive
Quicklinx: BGZ6WS00 Mfr#: 67Y2619
2.5" SAS Hot Swap Hard Drives are intended for ThinkServer solutions which require the best storage performance. 6Gb/s Hard Drives are an important part of the total 6Gb/s solution which also requires 6Gb/s backplane support and 6Gb/s RAID controllers.
Lenovo - hard drive - 300 GB - SAS
Hard drive - hot-swap
300 GB
2.5"
SAS
Data Transfer Rate
600 MBps
Spindle Speed
10000 rpm
ThinkServer RD330 (2.5"); RD340 (2.5"); RD440 (2.5"); RD540 (2.5"); RD640 (2.5"); TD330 (2.5"); TD340 (2.5"); TS430 (2.5")
300 GB
2.5"
SAS
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
10000 rpm
Expansion & Connectivity
1 x SAS
Compatible Bay
2.5"
Lenovo ThinkServer RD330 (2.5") , Lenovo ThinkServer RD340 (2.5") , Lenovo ThinkServer RD440 (2.5") , Lenovo ThinkServer RD540 (2.5") , Lenovo ThinkServer RD640 (2.5") , Lenovo ThinkServer TD330 (2.5") , Lenovo ThinkServer TD340 (2.5") , Lenovo ThinkServer TS430 (2.5")
