ThinkServer 7.2K 3.5inch Enterprise 6Gbps SATA Hot Swap Hard Drive provides customers with a very cost-effective way to have a large capacity SATA drive for data storage. These drives are ideal for capacity-intensive, sequential read applications such as storing content or data archiving.
- Lenovo - hard drive - 1 TB - SATA 6Gb/s
- Hard drive - hot-swap
- Capacity
- 1 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Spindle Speed
- 7200 rpm
- 10.16 cm x 14.7 cm x 2.61 cm
- 440 g
- 1-year warranty
- Designed For
- ThinkServer RD330 (3.5"); RD340 (3.5"); RD440 (3.5"); RD530 (3.5"); RD540 (3.5"); RD630 (3.5"); RD640 (3.5"); TD330 (3.5"); TD340 (3.5"); TS430 (3.5"); TS440 (3.5")
- Capacity
- 1 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- 10.16 cm
- 14.7 cm
- 2.61 cm
- 440 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5" x 1/3H
- Limited warranty - 1 year
- 0 °C
- 60 °C
- 5 - 95%
- Designed For
- Lenovo ThinkServer RD330 (3.5") , Lenovo ThinkServer RD340 (3.5") , Lenovo ThinkServer RD440 (3.5") , Lenovo ThinkServer RD530 (3.5") , Lenovo ThinkServer RD540 (3.5") , Lenovo ThinkServer RD630 (3.5") , Lenovo ThinkServer RD640 (3.5") , Lenovo ThinkServer TD330 (3.5") , Lenovo ThinkServer TD340 (3.5") , Lenovo ThinkServer TS430 (3.5") , Lenovo ThinkServer TS440 (3.5")
