The ThinkPad X395 easily slips into a bag or tucks under your arm. It's powered by a fast processor, which means longer battery life, faster processing, and higher power efficiency.
Faster, smoother, more powerful
2nd Gen AMD Ryzen Pro APU and Vega graphics increase CPU frequency and improve GPU performance. With AMD power, your ThinkPad X395 runs more efficiently and enhances battery life and audio performance. And with AMD FreeSync, available on the FHD display, stuttering and tearing are eliminated, and dynamic frame rates are optimized-you'll enjoy videos and gaming all the more. -
Displays that dazzle
Choose from several display options, including an FHD IPS on-cell touchscreen for enhanced battery life, an FHD IPS non-touch screen, and an HD TN display. No matter which choice you make, the super-slim bezel design adds a sleek look to your ThinkPad X395. -
Tested for battle, built for life
Like all ThinkPads laptops, the X395 is tested against 12 military-grade requirements and more than 200 quality checks to ensure they run in extreme conditions. From the Arctic wilderness to desert dust storms, from zero gravity to spills and drops, you can trust this laptop to handle whatever life throws your way. -
Battery life that keeps up with you
When you're on the go, you can't be worried about finding electrical outlets. That's why the ThinkPad X395 delivers up to 14.5 hours of battery life. And if you're running low, Rapid Charge technology provides 80% capacity in just an hour. So with a 60-minute layover, you can easily boost your battery up to more than 11.5 hours. -
A laptop that's well connected
Whether you're on the go or working at your desk, the X395 keeps you online with the optional LTE-A card. This WWAN technology lets your laptop function like a smartphone-where there's cellular service you can always jump online, even if there's no WiFi available. And you can trust that your connection is secure.
- Lenovo ThinkPad X395 - 13.3" - AMD Ryzen 5 Pro 3500U - 16 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- AMD Ryzen 5 Pro 3500U / 2.1 GHz (3.7 GHz) / 4 MB Cache
- Memory
- 16 GB DDR4 (provided memory is soldered)
- Storage
- 256 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 13.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- AMD Radeon Vega 8
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Battery
- Up to 14.5 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 31.19 cm x 21.72 cm x 1.69 cm
- 1.28 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 16 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2666 MHz
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 13.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Colour Gamut
- 72%
- Anti-glare, 170° viewing angle
Audio & Video
- Graphics Processor
- AMD Radeon Vega 8
- Camera
- Yes - 720p
- Camera Features
- IR camera, ThinkShutter camera privacy
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Audio Premium
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 9260
- Gigabit Ethernet via optional Ethernet (RJ-45) adapter
- DASH
- Technology
- Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 14.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- USB 3.1 Gen 2 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , Headphone/microphone combo jack , HDMI , Lenovo Ethernet extension connector , Dock
- Memory Card Reader
- Yes (microSD)
- Black
- Case Material
- Glass-fibre, magnesium-aluminum alloy, polyphenylene sulfide
- Dockable
- Security
- Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- RoHS
- Localization
- TopSeller
- 1.28 kg
Sustainability Information
- ENERGY STAR Certified
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter | In Stock | £26.01 |
Lenovo 65W Standard AC Adapter USB-C | In Stock | £29.56 |
Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 | In Stock | £29.56 |
Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £199.18 |
Kensington Security Cable Lock | In Stock | £23.65 |
Other bundles (14)
Lenovo ThinkPad USB 3.0 Secure HDD-500GB | In Stock | £143.11 |
Lenovo HDMI to VGA Monitor Adapter | In Stock | £23.20 |
Lenovo USB3.0 To VGA/HDMI Adapter | In Stock | £63.85 |
Lenovo 2m HDMI Cable | In Stock | £17.02 |
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £40.20 |
Lenovo Professional Wireless Keyboard | In Stock | £53.21 |
Lenovo ThinkPad Ethernet Extension Adapter Gen 2 | In Stock | £24.84 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.07 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £26.08 |
Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor | In Stock | £258.14 |
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £201.00 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor | In Stock | £336.70 |
Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor | In Stock | £314.26 |
