Lenovo ThinkPad X390 Intel Core i7-8565U 16GB 512GB SSD 13.3" Windows 10 Professional 64-bit
Quicklinx: F93HWS00 Mfr#: 20NN002NUK
  • Core i7
  • IEEE 802.11n
Meet the ThinkPad X390 Yoga - a remarkably portable 13" 2-in-1 business laptop. Convert it between four modes to match your needs, without sacrificing Lenovos easy-to-use side-docking capability. It also has an integrated ThinkPad Pen Pro, enhanced security measures, up to 14.5 hours of battery life, dual far-field microphones, optional global LTE capability, and more. No matter the situation, the versatility of the ThinkPad X390 Yoga will keep you ready for whatever the workday throws at you.
  • Uncompromising design
    The ThinkPad X390 Yoga is designed for both flexibility and reliability. Convert it easily between Laptop, Tablet, Stand and Tent modes, depending on your needs at the time. Use its integrated ThinkPad Pen Pro to unleash your creativity as you sketch, sign documents, or take notes. For the first time with an X Series Yoga, connect it to a ThinkPad Mechanical Dock (sold separately) via USB-C side mechanical docking, so you can easily use it with peripherals like monitors or keyboards and mice at the office.
  • Steadfast security
    Add an optional Hybrid IR (infrared) camera and touch fingerprint reader to securely log in with Windows Hello - just a view of your face or a touch of your finger will have you up and running almost instantly. No need to worry about outsiders hacking your webcam to spy on you; this 2-in-1 includes ThinkShutter, a physical cover that ensures your camera is looking at you only when you want it to be.
  • Packs a punch
    The ThinkPad X390 Yoga carries some serious power in its streamlined design. Take productivity on the go.
  • Take it anywhere and everywhere
    Slim and light, the ThinkPad X390 Yoga is engineered for mobility. Its battery will keep you productive as you go. Once it's time to recharge, you can bring it up to 80 percent capacity with just 60 minutes' charge. With optional global LTE-A WWAN, you'll stay connected no matter where you go.
Lenovo ThinkPad X390 Yoga - 13.3" - Intel Core i7 - 8565U - 16 GB RAM - 512 GB SSD - 4G LTE - UK
Notebook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) - 8565U / 1.8 GHz (4.6 GHz) / 8 MB Cache
16 GB DDR4 (provided memory is soldered)
Storage
512 GB SSD - TCG Opal Encryption 2, NVMe
Display
13.3" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics
Input Device
Digitizer, TrackPoint, digital pen, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
Wireless Broadband (WWAN)
4G LTE
Up to 14.5 hours
3-axis gyro sensor, 3-axis accelerometer
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
31.04 cm x 21.9 cm x 1.595 cm
1.29 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
SAR
1.696 W/kg (body), 1.696 W/kg (limb)
Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (8th Gen) 8565U / 1.8 GHz
Max Turbo Speed
4.6 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Integrated memory controller
RAM
16 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2666 MHz
Storage
Main Storage
512 GB SSD M.2 2280 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
13.3" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Colour Gamut
72%
Glossy, anti-reflective, anti-smudge, 170° viewing angle
Audio & Video
Graphics Processor
Intel UHD Graphics
Camera
Yes - 720p
Camera Features
IR camera, ThinkShutter camera privacy
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3287
High Definition Audio, Dolby Audio Premium
Input
Keyboard, digitizer, TrackPoint, digital pen, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560
Gigabit Ethernet via optional Ethernet (RJ-45) adapter
Generation
4G
LTE
Controller
FIBOCOM L830-EB - M.2 Card
Lithium Ion
50 Wh
Run Time
Up to 14.5 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
Slots
1 x Nano-SIM card (1 free)
USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , HDMI , Dock , Headphone/microphone combo jack , Lenovo Ethernet extension connector
Memory Card Reader
Yes (microSD)
Case Material
Carbon fibre
Integrated Options
Dockable
Security
Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ThinkPad Pen Pro, USB-C power adapter
RoHS
SAR Value
Localization
TopSeller
1.29 kg
Sustainability Information
ENERGY STAR Certified
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
F93H Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter In Stock £26.01
F93H Lenovo 65W Standard AC Adapter USB-C In Stock £29.56
F93H Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 In Stock £29.56
F93H Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do In Stock £194.89
F93H Kensington Security Cable Lock In Stock £23.65
Other bundles (14)
F93H Lenovo ThinkPad USB 3.0 Secure HDD-500GB In Stock £143.11
F93H Lenovo HDMI to VGA Monitor Adapter In Stock £23.20
F93H Lenovo USB3.0 To VGA/HDMI Adapter In Stock £63.85
F93H Lenovo 2m HDMI Cable In Stock £17.02
F93H Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 In Stock £41.29
F93H Lenovo Professional Wireless Keyboard In Stock £53.47
F93H Lenovo ThinkPad Ethernet Extension Adapter Gen 2 In Stock £25.51
F93H Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.07
F93H Lenovo Essential Wired Keyboard and Mouse Combo - UK English In Stock £25.39
F93H Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor In Stock £258.14
F93H Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor In Stock £202.02
F93H Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor In Stock £454.54
F93H Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor In Stock £336.70
F93H Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor In Stock £312.68
