Meet the ThinkPad X390 Yoga - a remarkably portable 13" 2-in-1 business laptop. Convert it between four modes to match your needs, without sacrificing Lenovos easy-to-use side-docking capability. It also has an integrated ThinkPad Pen Pro, enhanced security measures, up to 14.5 hours of battery life, dual far-field microphones, optional global LTE capability, and more. No matter the situation, the versatility of the ThinkPad X390 Yoga will keep you ready for whatever the workday throws at you.
Uncompromising design
The ThinkPad X390 Yoga is designed for both flexibility and reliability. Convert it easily between Laptop, Tablet, Stand and Tent modes, depending on your needs at the time. Use its integrated ThinkPad Pen Pro to unleash your creativity as you sketch, sign documents, or take notes. For the first time with an X Series Yoga, connect it to a ThinkPad Mechanical Dock (sold separately) via USB-C side mechanical docking, so you can easily use it with peripherals like monitors or keyboards and mice at the office. -
Steadfast security
Add an optional Hybrid IR (infrared) camera and touch fingerprint reader to securely log in with Windows Hello - just a view of your face or a touch of your finger will have you up and running almost instantly. No need to worry about outsiders hacking your webcam to spy on you; this 2-in-1 includes ThinkShutter, a physical cover that ensures your camera is looking at you only when you want it to be. -
Packs a punch
The ThinkPad X390 Yoga carries some serious power in its streamlined design. Take productivity on the go. -
Take it anywhere and everywhere
Slim and light, the ThinkPad X390 Yoga is engineered for mobility. Its battery will keep you productive as you go. Once it's time to recharge, you can bring it up to 80 percent capacity with just 60 minutes' charge. With optional global LTE-A WWAN, you'll stay connected no matter where you go.
- Lenovo ThinkPad X390 Yoga - 13.3" - Intel Core i5 - 8265U - 8 GB RAM - 256 GB SSD - 4G LTE - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i5 (8th Gen) - 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 256 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 13.3" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics
- Input Device
- Digitizer, TrackPoint, digital pen, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Wireless Broadband (WWAN)
- 4G LTE
- Battery
- Up to 14.5 hours
- 3-axis gyro sensor, 3-axis accelerometer
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 31.04 cm x 21.9 cm x 1.595 cm
- 1.29 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- SAR
- 1.696 W/kg (body), 1.696 W/kg (limb)
- Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2666 MHz
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 13.3" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Colour Gamut
- 72%
- Glossy, anti-reflective, anti-smudge, 170° viewing angle
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- IR camera, ThinkShutter camera privacy
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Audio Premium
Input
- Keyboard, digitizer, TrackPoint, digital pen, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560
- Gigabit Ethernet via optional Ethernet (RJ-45) adapter
- Generation
- 4G
- Technology
- LTE
- Controller
- FIBOCOM L830-EB - M.2 Card
- Technology
- Lithium Ion
- Capacity
- 50 Wh
- Run Time
- Up to 14.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Slots
- 1 x Nano-SIM card (1 free)
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , HDMI , Dock , Headphone/microphone combo jack , Lenovo Ethernet extension connector
- Memory Card Reader
- Yes (microSD)
- Black
- Case Material
- Carbon fibre
- Integrated Options
- Dockable
- Security
- Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- ThinkPad Pen Pro, USB-C power adapter
- RoHS
- SAR Value
- Localization
- TopSeller
- 1.29 kg
Sustainability Information
- ENERGY STAR Certified
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter | In Stock | £26.01 |
Lenovo 65W Standard AC Adapter USB-C | In Stock | £29.56 |
Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 | In Stock | £29.56 |
Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £194.89 |
Kensington Security Cable Lock | In Stock | £23.65 |
Other bundles (13)
Lenovo ThinkPad USB 3.0 Secure HDD-500GB | In Stock | £143.11 |
Lenovo HDMI to VGA Monitor Adapter | In Stock | £23.20 |
Lenovo USB3.0 To VGA/HDMI Adapter | In Stock | £63.85 |
Lenovo 2m HDMI Cable | In Stock | £17.02 |
Lenovo Professional Wireless Keyboard | In Stock | £53.47 |
Lenovo ThinkPad Ethernet Extension Adapter Gen 2 | In Stock | £25.51 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.07 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor | In Stock | £258.14 |
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £202.02 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor | In Stock | £336.70 |
Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor | In Stock | £321.24 |
