You work hard. You're flexible. When life says, "Go," you never slow down. The sleek ThinkPad X380 Yoga is designed for you. This stylish powerhouse adapts to work with you - as a laptop, tablet, or anything in between. Moreover, hardware-level security features provide peace of mind when you're on-the-go.
An IT administrator's dream
Users can quickly, and securely, log in with ease - just the touch of the finger or the view of their face if they opt for the IR camera and use Windows Hello. What's more, the fingerprint reader thwarts biometric hacking with anti-spoofing technology - the fingerprint image is saved inside the chip so it's not sent out for login authentication when you sign in. -
Use it your way
A 360-degree hinge means you can lay the ThinkPad X380 Yoga flat, fold it up, or use it however your environment demands. Whether a tight-elbowed seat on a flight, a bumpy train ride, or your couch, the ThinkPad X380 Yoga has a mode to suit you. -
Unleash your creativity
The ThinkPad X380 Yoga comes with a built-in, rechargeable ThinkPad Pen Pro, so you never need to worry about running out of ink, needing batteries, or misplacing it. Take notes. Sketch your latest designs. Sign documents. Even make annotations to your documents. -
Down with dongles
Connecting on the road - or even in your own conference room - 2 can be a hassle. That's why the ThinkPad X380 Yoga is packed with a robust number of ports - including Thunderbolt, USB 3.0, HDMI, and more.
- Lenovo ThinkPad X380 Yoga - 13.3" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD - 4G LTE - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) - 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 256 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 13.3" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- Digitizer, TrackPoint, digital pen, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Wireless Broadband (WWAN)
- 4G LTE
- Service Provider
- Service not included
- Battery
- Up to 13.6 hours
- Ambient light sensor, 3-axis gyro sensor, 3-axis magnetometer, 3-axis accelerometer, 3-axis compass
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 31.35 cm x 22.22 cm x 1.82 cm
- 1.43 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- SAR
- 1.36 W/kg (body), 1.36 W/kg (limb)
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 13.3" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-reflective, anti-smudge
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, dual array microphone
- Codec
- CX11771
- High Definition Audio
Input
- Keyboard, digitizer, TrackPoint, digital pen, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch clickpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - M.2 Card
- Ethernet Controller
- Intel I219-V
- Gigabit Ethernet via optional Ethernet (RJ-45) adapter
- Generation
- 4G
- Technology
- LTE
- Controller
- FIBOCOM L830-EB - M.2 Card
- Service Provider
- Technology
- Lithium Ion
- Capacity
- 51 Wh
- Run Time
- Up to 13.6 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Slots
- 1 x Nano-SIM card (1 free)
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , USB-C 3.1 Gen 2 (supports Thunderbolt 3) , HDMI , Headphone/microphone combo jack , Lenovo Ethernet extension connector
- Memory Card Reader
- Yes (microSDXC UHS)
- Black
- Case Material
- Carbon fibre
- Integrated Options
- Security
- Administrator password, hard drive password, power-on password, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington mini security slot
- Included Accessories
- Power adapter, ThinkPad Pen Pro
- RoHS
- SAR Value
- Localization
- TopSeller
- 1.43 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
Essential Accessories (7)
Get more from your purchase from one of our essential accessories
Lenovo ThinkPad 45W AC Adapter (slim tip) | In Stock | £24.84 |
Lenovo ThinkPad 65W AC Adapter (Slim Tip) | In Stock | £34.46 |
Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter | In Stock | £26.01 |
Lenovo 65W Standard AC Adapter USB-C | In Stock | £29.56 |
Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 | In Stock | £27.29 |
Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £199.18 |
Kensington Security Cable Lock | In Stock | £23.65 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
Lenovo TopSeller Epac ThinkPad Warranty Upgrade to 3 Year On-Site Next Business Day | In Stock | £267.14 |
Other bundles (14)
Lenovo ThinkPad USB 3.0 Secure HDD-500GB | In Stock | £143.11 |
Lenovo HDMI to VGA Monitor Adapter | In Stock | £23.20 |
Lenovo USB3.0 To VGA/HDMI Adapter | In Stock | £63.85 |
Lenovo 2m HDMI Cable | In Stock | £17.02 |
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £40.20 |
Lenovo Thinkpad Pen Pro for Yoga 260 | In Stock | £29.56 |
Lenovo Professional Wireless Keyboard | In Stock | £53.21 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.07 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £26.08 |
Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor | In Stock | £258.14 |
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £201.00 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor | In Stock | £336.70 |
Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor | In Stock | £314.26 |
