You work hard. You're flexible. When life says, "Go," you never slow down. The sleek ThinkPad X380 Yoga is designed for you. This stylish powerhouse adapts to work with you - as a laptop, tablet, or anything in between. Moreover, hardware-level security features provide peace of mind when you're on-the-go.
An IT administrator's dream
Users can quickly, and securely, log in with ease - just the touch of the finger or the view of their face if they opt for the IR camera and use Windows Hello. What's more, the fingerprint reader thwarts biometric hacking with anti-spoofing technology - the fingerprint image is saved inside the chip so it's not sent out for login authentication when you sign in. -
Use it your way
A 360-degree hinge means you can lay the ThinkPad X380 Yoga flat, fold it up, or use it however your environment demands. Whether a tight-elbowed seat on a flight, a bumpy train ride, or your couch, the ThinkPad X380 Yoga has a mode to suit you. -
Unleash your creativity
The ThinkPad X380 Yoga comes with a built-in, rechargeable ThinkPad Pen Pro, so you never need to worry about running out of ink, needing batteries, or misplacing it. Take notes. Sketch your latest designs. Sign documents. Even make annotations to your documents. -
Down with dongles
Connecting on the road - or even in your own conference room - 2 can be a hassle. That's why the ThinkPad X380 Yoga is packed with a robust number of ports - including Thunderbolt, USB 3.0, HDMI, and more.
- Lenovo ThinkPad X380 Yoga - 13.3" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) - 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 256 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 13.3" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- Digitizer, TrackPoint, digital pen, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- Up to 13.6 hours
- Ambient light sensor, 3-axis gyro sensor, 3-axis magnetometer, 3-axis accelerometer, 3-axis compass
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 31.35 cm x 22.22 cm x 1.82 cm
- 1.43 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- SAR
- 1.36 W/kg (body), 1.36 W/kg (limb)
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2400 MHz
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 13.3" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-reflective, anti-smudge
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, dual array microphone
- Codec
- CX11771
- High Definition Audio
Input
- Keyboard, digitizer, TrackPoint, digital pen, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch clickpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - M.2 Card
- Ethernet Controller
- Intel I219-V
- Gigabit Ethernet via optional Ethernet (RJ-45) adapter
- Technology
- Lithium polymer
- Capacity
- 51 Wh
- Run Time
- Up to 13.6 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- USB 3.1 Gen 1 (Always On) , USB 3.1 Gen 1 , USB-C Gen 2 (supports Thunderbolt 3) , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSDXC UHS)
- Black
- Case Material
- Carbon fibre
- Integrated Options
- Security
- Administrator password, hard drive password, power-on password, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington mini security slot
- Included Accessories
- Power adapter, ThinkPad Pen Pro
- RoHS
- SAR Value
- Localization
- TopSeller
- 1.43 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
